Rag joint replacement with u-joint? #1580667
02/18/14 05:03 AM
02/18/14 05:03 AM
Monroe, LA USA
Carsavior Offline OP
Monroe, LA USA
65 New Yorker with a 413 and hi-po manifolds. The rag joint assy will touch the flange on the manifold when accelerating. Need to replace the rag joint with something having a smaller diameter. Saw a u-joint on the flaming river site that looks like it might work. Anybody ever use one of these rag joint replacements? Know how they go in? Do you have to cut one of the shafts? Thanks- Pat
Re: Rag joint replacement with u-joint? [Re: Carsavior] #1580668
02/22/14 09:51 PM
02/22/14 09:51 PM
Monroe, LA USA
Monroe, LA USA
Anyone?
Re: Rag joint replacement with u-joint? [Re: Carsavior] #1580669
02/22/14 11:05 PM
02/22/14 11:05 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
Did one on my Duster and the instructions state to cut the shaft and I had to.
Duster had a plunge joint however not a rag joint. Knowing more about body flex and the like I wouldn't do it again.
Re: Rag joint replacement with u-joint? [Re: PossessedDuster] #1580670
02/23/14 12:27 AM
02/23/14 12:27 AM
IN
ahy Offline
ahy  Offline
IN
The rag joint takes out flex of the body/frame under load and is a safety feature in case of front collision. Suggest you keep it. Stiffer engine mounts (eg Schumacher poly locks) and/or shimming the engine mounts up a little may be a better solution.
Re: Rag joint replacement with u-joint? [Re: Carsavior] #1580671
02/23/14 10:14 AM
02/23/14 10:14 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Several guys over at FCBO have done it and its been discussed quite thoroughly over there. General consensus: Go with the U-joint.
Re: Rag joint replacement with u-joint? [Re: Commando1] #1580672
02/24/14 01:25 AM
02/24/14 01:25 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Flaming River
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Rag joint replacement with u-joint? [Re: Commando1] #1580673
02/24/14 07:10 AM
02/24/14 07:10 AM
Monroe, LA USA
Monroe, LA USA
FCBO?
Re: Rag joint replacement with u-joint? [Re: Carsavior] #1580674
02/24/14 09:29 AM
02/24/14 09:29 AM
Commando1 Offline
Commando1  Offline
Re: Rag joint replacement with u-joint? [Re: Commando1] #1580675
02/27/14 12:10 AM
02/27/14 12:10 AM
Monroe, LA USA
Monroe, LA USA
Thx- I'll check it out!
Re: Rag joint replacement with u-joint? [Re: hemi-itis] #1580676
02/28/14 05:37 PM
02/28/14 05:37 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Do you have a part number for the Flaming River "U" joint?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
