Re: Adding Methanol to E-85
[Re: hemidup]
#1580339
02/17/14 07:29 PM
02/17/14 07:29 PM
Quicktree
From my understanding both E70 and E85 have the same octane rating, but E85 has a slower burn rate helping your engine run cooler.
the higher octane gas mixed with it raises the octane level
[Re: hemidup]
#1580343
02/17/14 10:14 PM
02/17/14 10:14 PM
Posts: 8,172 Plymouth, MI
Blusmbl
Plymouth, MI
I believe the octane is similar, the problem is if you're used to E85 you'll have to jet down for E70.
[Re: 69dart]
#1580344
02/17/14 10:31 PM
02/17/14 10:31 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
By April the speedway stations will have plenty of E85. Lowest i have seen is still over 80% so i woulnt worry about it.
Yes this is true. And bill remember My car is broke and I have 30 gal of e-85
[Re: VernMotor]
#1580345
02/17/14 11:13 PM
02/17/14 11:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Bill... buy Jamies E-85... dont cross blend meth and ethanol... dont chance buying unless you test it... I still have some if needed but it would be a drive... E-98 is the max.... its blended down to that so it isnt drinking liquor which would be taxed that way at the plant
[Re: Dodgem]
#1580347
02/18/14 12:00 AM
02/18/14 12:00 AM
Posts: 3,453 Dandridge TN
Dabee
Dandridge TN
They used to sell M80 and yea you can mix meth with ethanol specific gravities are nearly the same Dabeast2 member hear can only get E70 and I new he and a drum and 1/2 of meth so he mixed it with a tester to make EM85 till he used up all his methanol now he buys the E98 and mixes his own E85 using a tester quite simple!
Yep I'm guilty". I mixed methanol with E70 for one whole season (250 passes) and never had an issue with it. When I ran out of meth I bought E98 and mixed it with E70 to get up to E85 (another 250 passes) and no issues. I seen no difference in performance between the two. I'm out of E98 so this year I'm going to run E70 to see what it does. I believe all I'll need to do is jet for the E70. I tune using an AFR gauge set to read on the Lambda scale and tune it for 80 to 85 Lambda just before I cross the strip. That's 15 to 20% rich. Mix it one to one. One gallon of E70 to one gallon of ethanol or methanol and you will have E85 or EM85. Always test your mixture.
[Re: DoubleD]
#1580348
02/18/14 01:18 AM
02/18/14 01:18 AM
Posts: 43,248 Bend,OR USA
Cab_Burge
E85 is ethanol and gas – I know methanol and gasoline do not mix well and can separate depending on the ratio – plus methanol is much more corrosive fuel and has less BTU value. So in short you actually may be creating a much weaker fuel - Seems to me I would avoid playing the mad scientist role!
Me thinks you have the BTU values backwards on Methanol and Ethanol, I beleive Methanol has 85,000 BTU and Ethanol has slightly less, around 83,000 to 84,000 That is the reason most NHRA alcholol cars race with Methanol Your correct on the corrosiveness of Methanol, I had to find out about that the hard way Ethanol has some of the same charasictics(SP?) but not as bad OP, I beleive you can go to a paint or hardware store and buy Ethanol in a can, they use it for cleaning up on painting and varnishing jobs I'm in the same boat out here, our winter mix tests to be right at 75%
Sorry Cab but:
Gasoline 124,340 BTU/gal
E85 Approx 100,000 BTU/gal
Ethanol 84,530 BTU/gal
Methanol 65,200 BTU/gal
Hence the reason you need twice as much Methonal to get the same pop as Gasoline
I went on line, don't we love new technology and saw that the Gov. energy web page show similar numbers to your chart The last chemical BTU chart I saw was probally back in the 1980, when pump # 2 deisilfuel had 230,000 BTU, Gasoline had around 130,000 BTU and Metanol had 85,000 and Ethanol had 84,000 BTU, Propane, Butane and LNG all had less than 57,000 BTU per liquid gallon Now with the new cleaner fuels I saw that low sulpher #2 deisel now has around 124,000 BTU, gasoline varied from 111,836 to 116,090 BTU, the same chart did show Ethanol to between 76,000 and 76,330 BTU and the current Methanol to have 57,250 BTU My apologies to you for not having the current numbers, sorry It is to bad that the BTU in fuel have been downgraded for what ever reason Eenergy is used to make heat in internal combustion engines, the less BTU per gallon the shorter the distance it will propel a vechicle Bring back the old diesel # 2 please
[Re: VernMotor]
#1580349
02/18/14 03:32 AM
02/18/14 03:32 AM
dartman366
Mt. Vernon, Ohio
Thanks Guys, I always test at the pump before I buy so there is no doubt, I have a little over 25 gallon so I should be good for a weekend or so, Jamie I will keep that in mind, I won't need it if what Shaun says is true, but if I do......
