87 Ram 50 V8 Swap #1580214
02/17/14 11:36 AM
02/17/14 11:36 AM
AZ
Mike P Offline OP
Mike P  Offline OP
AZ
I've had an 2WD 87 Ram 50 stashed away for several years, good body, decent interior, bad motor. Lately I’ve been kicking around pulling it into the shop and doing a V8 swap on it. I’ve seen/read about various swaps including SB MOPAR, SB Ford and even SB Chevys into these.
I’m kind of thinking 318 with an 833 overdrive 4 speed (if the tag is correct it has 3.91 gears in it). It currently has a 5 speed with a cable operated clutch.
Anybody here done a V8 swap (any brand engine) into one of these? I’m looking for insight on front spring upgrades, fitment issues, PS upgrade etc.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 87 Ram 50 V8 Swap [Re: Mike P] #1580215
02/17/14 05:45 PM
02/17/14 05:45 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If I remember right, the distance between the firewall and the radiator mount is pretty short. You have to cut the grill to mount the rad in front of the rad support. Time to drag out the tape measure.
I put a D 50 cab & front clip on a 77 Jeep J 10 that had an AMC 360 4v. Think I added 4" in the center of both fenders to clear everything. That D 50 cab is very light. That Jeep was a lot of fun. In 4x4, from a standing start, wide open throttle would jump the whole truck off the ground, but you had to wear a helmet or you hit your head on the roof doing 4x4 ditches and such. The jeep was junk, the D 50 was junk, nothing to loose = lots of fun. Gene
Re: 87 Ram 50 V8 Swap [Re: poorboy] #1580216
02/17/14 08:42 PM
02/17/14 08:42 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
V6
I am truckless..
Re: 87 Ram 50 V8 Swap [Re: Mike P] #1580217
02/17/14 09:00 PM
02/17/14 09:00 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
If you've read about it then you should already know. I've seen a couple with V-8 swaps and little else. Look cool, sound cool, make more tire smoke than anything.
You'd really have to commit to frame and suspension upgrades to make it comfortable to stab the long pedal.
Re: 87 Ram 50 V8 Swap [Re: redraptor] #1580218
02/17/14 10:27 PM
02/17/14 10:27 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
There is a member on the race forum with a small block d50.
user D-50
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: 87 Ram 50 V8 Swap [Re: 73swinger] #1580219
02/18/14 04:08 AM
02/18/14 04:08 AM
GEORGIA
barracuda7199 Offline
GEORGIA
It can be done. 340 in our 87 D50
Re: 87 Ram 50 V8 Swap [Re: barracuda7199] #1580220
02/22/14 12:37 AM
02/22/14 12:37 AM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
Yup, I remember reading about a 340 in a late '70's Arrow pickup. Same chassis I'd imagine.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: 87 Ram 50 V8 Swap [Re: GO_Fish] #1580221
02/22/14 02:47 AM
02/22/14 02:47 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
My brother built one with a mild 360 back in the late 90's.
The only detail I really remember was a FWD Daytona radiator was mounted directly behind the grille because there was no room where it should have been. He ran a 904, stock rear end, wheels, tires, brakes, suspension...everything. I also believe he had to run 2 hood pins due to the hood latch assembly being in the way of where the radiator had to go. The truck was built out of spare parts and purely for fun. He drove it for a couple years and sold it to a friend in Springfield, MO.
Was it safe? No. Did it handle? Not a chance. Was it fun? You bet. The look of the then-new Corvette owner and his trophy wife/girlfriend having a red beat up, rusty truck out-accelerate them was priceless.
I've got a picture of it around here somewhere...have to see if I can dig it up.
Re: 87 Ram 50 V8 Swap [Re: Blues_Cuda] #1580222
03/08/14 07:52 PM
03/08/14 07:52 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
I will post pic. if it is not to big. This is a 1980 D-50.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: 87 Ram 50 V8 Swap [Re: Blues_Cuda] #1580223
03/16/14 04:39 PM
03/16/14 04:39 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Happened to run across a picture of the D50 my brother built and remembered this post from last month. Quite the sleeper.
Re: 87 Ram 50 V8 Swap [Re: Blues_Cuda] #1580224
03/16/14 04:44 PM
03/16/14 04:44 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
No engine shots that I can recall.
