Diesel 727 rebuild
#1580054
02/16/14 10:52 PM
02/16/14 10:52 PM
Posts: 5,275 near Harrisburg, Pa
440trk
near Harrisburg, Pa
Truck: 91 Cummins 727 4x4 w/ 3.07 rear gear.
I have a spare Cummins trans from a 1990 W250, that I'm planning to get rebuilt in the near future. This trans will be going into the truck listed above. I'm looking for suggestions on parts/upgrades, as well as any pitfalls that should be addressed.
Currently I'm looking into using a Mopar Performance rebuild kit, a Trans go TF-2, adding an aluminum deep pan, and also installing a new converter.
The truck is a semi-daily driver, and occasionally tows a 10k Dump Trailer (even with the crappy 3.07 gears). I'm interested in any improvements that I should look into, while the trans is apart. I believe that CRT recommends a heavy duty reinforced low reverse servo spring retainer when using the TF-2.
Are pumps usually of a point of failure with high mileage? Any recommendations on rebuild kits other than the MP kit?
I'm trying to keep the cost down, but there is some budget for improvements, if it means longevity of the trans.
Thanks! Mike (440trk)
Re: Diesel 727 rebuild
[Re: 440trk]
#1580056
02/17/14 12:48 AM
02/17/14 12:48 AM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
have you thought about using one with a l lock up convertor ? would hep fuel millage if yours does not have it ! a low stall convertor is a pluss! ![](/ubbthreads/images/graemlins/beer.gif)
[Re: calrobb2000]
#1580057
02/17/14 01:02 AM
02/17/14 01:02 AM
440trk
near Harrisburg, Pa
Yep, thought about it, but my truck already has the 3.07 gears. Also the cost to swap to a A518 or 47RH for a Diesel, along with the additional lock up converter expense, is not justifiable for me. ![](/ubbthreads/images/graemlins/coool.gif)
[Re: 383man]
#1580059
02/17/14 04:30 AM
02/17/14 04:30 AM
440trk
near Harrisburg, Pa
Thanks Ron, My truck has 235k on it and while I know these trucks were designed to go the miles while working....I have some concerns when towing 10k behind a 235k mile transmission, with a 3.07 gear. ![](/ubbthreads/images/graemlins/smile.gif) My "Spare" trans came out of a truck with I think 165k or so, but I have NO idea how it was treated. I'll plan on putting a pump in too. Thanks!
