Does anyone know if thee's enough meat on the underside of the manifold to grind some away?
Here's the deal--- my latest project has the new x-ram on it & a set of cast aluminum valvecovers from Ray Barton. The whole set-up looks good in my '68 A-body but I can't pull the valvecovers off!
It seems the casting is too thick or the x-ram protrudes out too far, or both, to allow me to clear the inner fender. My initial thought is there just might be enough material on the x-ram to allow some grinding to give me a 1/8in or so that I need clear. OR does anyone know of a "thin" (?) valve cover that'll clear the manifold & still allow me to use the Barton rockerarm system?
