Turn signal - Hazzards Flashing
#1579675
02/16/14 12:14 PM
02/16/14 12:14 PM
Posts: 325 IL
Rawone
IL
Barn Find 1969 roadrunner. We installed a battery last night and had an issue. Turn signal activated the Hazzard lights...all blinking even in the dash( turn signal indicators flashing ). any thoughts as to what the issue is...Flasher? Turn signal switch? or? I appreciate any help! Thanks in advance, Scott
Re: Turn signal - Hazzards Flashing
[Re: Rawone]
#1579677
02/16/14 12:50 PM
02/16/14 12:50 PM
RapidRobert
Crossed wires/connections somewhare. On that (69RR) is the hazard switch in the columm? I'd seperate the TS/brake harness under the col & start checking continuities which will tell you if the problem is in the col TS switch/its' harness or downstream. The wiring diagrams at www.mymopar.com will likely help. there are 2 flasher cans.
[Re: RapidRobert]
#1579679
02/16/14 02:11 PM
02/16/14 02:11 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
reach under the dash and unplug the 4-way switch. if all the lights still flash then the turn signal switch is bad/corroded. or as stated above, something is plugged in wrong but i doubt that.
