Re: 1996 Neon Oil Pressure Sending unit
[Re: rth]
#1579642
02/16/14 01:25 PM
02/16/14 01:25 PM
Posts: 12,181 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The plastic connectors can be a pain to get off sometimes. There is a red plastic lock that slides outward so that you can depress the release. Sometimes when you slide the red release, it will break and slide all the way out. Don't worry, it is not essential.
Occasionally, I will need to get a pair of needle nose pliers to depress the release, but it must be done carefully. Break the release and the plug won't stay on the switch.
IHTH
Master, again and still
