Re: Front Steer Rack Conversion - Part Deux
[Re: hemicop]
#1579466
02/17/14 01:23 PM
02/17/14 01:23 PM
Posts: 3,875 Smyrna, South Carolina
STEFF
I like it! So here's a question........... Do you plan on making & selling these for A-bodies using using coilovers & retaining the stock, or stock-type LCA?
I don't know that I will. There's plenty of aftermarket suspensions on the market already.
[Re: Stanton]
#1579469
02/17/14 04:44 PM
02/17/14 04:44 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
Steff, beautiful work as always but I thought the intent of the rack was to use an oil pan that wasn't so deep and now it looks like the whole front k frame is just about as deep as the pan
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: Stanton]
#1579470
02/17/14 04:51 PM
02/17/14 04:51 PM
Posts: 22,783 Bitopia
jcc
Bitopia
A number replies back a member suggested gusseting the tube angle welds. I was not a proponent of that solution. However for argument's sake, RMS originally used a similar welded non gusseted tube design, and then later changed to a bent square tube, with no intermediate welds. Never heard their reason for the change. The RMs was a 2" sq tube FWIW.
[Re: STEFF]
#1579471
02/17/14 05:04 PM
02/17/14 05:04 PM
Posts: 2,878 SE Nunya
Bubba
SE Nunya
[Re: sixpackgut]
#1579472
02/17/14 05:08 PM
02/17/14 05:08 PM
STEFF
The intent was to rid of the drag link going thru the oil pan and reduce the depth of the pan. The new k-frame hangs only 3/16" of an inch lower than the stock k-frame: stock = 7" vs mine = 7 3/16". The rack location dictated the depth. Without the drag link, I can now make the pan shorter in depth.
[Re: STEFF]
#1579473
02/17/14 05:51 PM
02/17/14 05:51 PM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I would imagine that once into production they would either bend or have those tubes bent simply to save the labor of angle cutting and welding. Given that a bent 2" square tube would end up with a very thin wall on the long radius I suspect there would be less strength in a bent piece than a properly welded piece.
They may also have done it for "appearance" and in this case they may have used bent flats for the top and bottoms, laser-cut sides and then welded all the seams. This is very common in the hotrod frame industry.
[Re: STEFF]
#1579474
02/17/14 05:53 PM
02/17/14 05:53 PM
sixpackgut
Charleston
oh wow, looks a lot deeper. very nice
[Re: sixpackgut]
#1579475
02/18/14 10:23 AM
02/18/14 10:23 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Nice work Steff! Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: STEFF]
#1579476
02/18/14 11:43 PM
02/18/14 11:43 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Looks great! I may toy around with something similar one of these days...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: cl440]
#1579478
02/20/14 06:06 PM
02/20/14 06:06 PM
jcc
Bitopia
Where did it break?
Looking closer at the attachment it "looks" like 6 1" tube braces were added?
[Re: jcc]
#1579480
02/21/14 02:08 AM
02/21/14 02:08 AM
Posts: 2,567 S.E. Michigan
cl440
S.E. Michigan
Where did it break?
Right side tube that runs front to back and has the dip in it to clear the rack. You can see the paint was ground away to weld the area.
