Page 1 of 5 1 2 3 4 5
Front Steer Rack Conversion - Part Deux - UPDATE!! #1579426
02/15/14 10:22 PM
02/15/14 10:22 PM
Smyrna, South Carolina
STEFF Offline OP
STEFF  Offline OP
After all of the critiques and criticisms of my attempt at installing a rack into a stock k-frame, and realizing it wasn't safe, and staring at that thing a million different ways to try to improve it, the best way to improve it was to place it in the dumpster and go back to a tubular k-frame. I needed to design it with no bent tubing components, being that I do not have a tube bender, yet. Here is what I came up with.
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579427
02/15/14 10:47 PM
02/15/14 10:47 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Nice!
Re: Front Steer Rack Conversion - Part Deux [Re: RV2] #1579428
02/15/14 10:54 PM
02/15/14 10:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That's impressive. Now, will it clear an oilpan ???
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579429
02/15/14 11:04 PM
02/15/14 11:04 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Wow, nice work Steff!
Re: Front Steer Rack Conversion - Part Deux [Re: LSP] #1579430
02/15/14 11:37 PM
02/15/14 11:37 PM
NW INDIANA
ta3834bbl Offline
ta3834bbl  Offline
NW INDIANA
I bet it will fit with a 6 qt truck rear sump oil pan just fine ???
67 Dart GT Convertible 273
68 Barracuda 383
68 Roadrunner 383 4spd
1 '01 Ram 2500 4x4 diesel
2 '02 Rams 1500 4x4's 4.7s
3 '03 Rams 2 1500's 4x4 and 1 2500 hemi 4x4
Oh, and a 03 Grand Cherokee and an '00 durango smile
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579431
02/15/14 11:47 PM
02/15/14 11:47 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Looks real good Steff... nice and strong... where will
the arms mount.. are you staying with double arms
or going strut
EDIT
Never mind.. I see the tube
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579432
02/15/14 11:50 PM
02/15/14 11:50 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Looks good. I was just thinking about doing this today. What front suspension??
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579433
02/16/14 12:10 AM
02/16/14 12:10 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
You know what I find most commendable, you took the criticism in Part 1, you studied it, you didn't make excuses, you got back on the horse, and you made it better. not many would/could do that.
Re: Front Steer Rack Conversion - Part Deux [Re: jcc] #1579434
02/16/14 12:16 AM
02/16/14 12:16 AM
1.5 miles west of Jacksonburg ...
Ohio Joe Offline
Ohio Joe  Offline
Very very nice looking , wish I were as talented.
66 Dart GT " Rat Racer"
Re: Front Steer Rack Conversion - Part Deux [Re: Ohio Joe] #1579435
02/16/14 01:38 AM
02/16/14 01:38 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Wish I had half yur talent...Looks awesome. And the best part is, you built it.
Re: Front Steer Rack Conversion - Part Deux [Re: Dragula] #1579436
02/16/14 01:54 AM
02/16/14 01:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
So, what do you use for front lower ball joints?
Re: Front Steer Rack Conversion - Part Deux [Re: jcc] #1579437
02/16/14 03:18 AM
02/16/14 03:18 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I dont know, Still looks very weak to me. She will probably bust on its first outing.
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579438
02/16/14 10:46 AM
02/16/14 10:46 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
How are you mounting the strut arms?
Jeff
69 GTX 68 Road Runner
Re: Front Steer Rack Conversion - Part Deux [Re: JERICOGTX] #1579439
02/16/14 11:11 AM
02/16/14 11:11 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Looks good, STEFF. Did you build a jig first, or did you tack everything together under the car? I assume you modeled it out first, to get all your cut lengths and angles?
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579440
02/16/14 12:25 PM
02/16/14 12:25 PM
gregsdart Offline
gregsdart  Offline
Class work there! Looks to be stout enough to take all the stress you could ever throw at it, including road racing.
Re: Front Steer Rack Conversion - Part Deux [Re: gregsdart] #1579441
02/16/14 12:31 PM
02/16/14 12:31 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Bulletproof for sure.
Yeah, it's got a smallblock.
Re: Front Steer Rack Conversion - Part Deux [Re: 340B5] #1579442
02/16/14 12:53 PM
02/16/14 12:53 PM
Q
Quicktree Offline
Quicktree  Offline
Q
sure looks nice but how heavy is it? CM or mild steel?
Re: Front Steer Rack Conversion - Part Deux [Re: STEFF] #1579443
02/16/14 01:20 PM
02/16/14 01:20 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That looks good Steff!
Re: Front Steer Rack Conversion - Part Deux [Re: ProSport] #1579444
02/16/14 01:45 PM
02/16/14 01:45 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Front Steer Rack Conversion - Part Deux [Re: pittsburghracer] #1579445
02/16/14 02:40 PM
02/16/14 02:40 PM
It does look good but I see a weak link. With the way forces come into play the top 2x3 and the down leg 2x3 tubes welded joint, I think you would need a gusset. When I did my frame rails I cut the sides and inside face of the angle and then folded it in so the outside face stayed as one continuos piece and welding was only required on three sides. I really like this piece though as I want to give this a go for my car but ended up buying an Alterkation unit.
