Re: Braided fuel questions.......... [Re: D-50] #1579349
02/17/14 11:18 PM
02/17/14 11:18 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That looks similar to mine w/Earls nylon line.................
Thumper are you using the Earls PRO-Lite 350 nylon hose? I have not decided what to use yet.
Thanks...
Yes...............
Re: Braided fuel questions.......... [Re: astjp2] #1579350
02/17/14 11:54 PM
02/17/14 11:54 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Each line has specific fittings for them, they are mostly 37* with others types being JIS and SAE 45*. You need to find the right fittings per the hose. Aeroquip and stratoflex have interchangeable ends, but most others are not made to the same standard. Tim
Will the Summit brand fittings that I have work on any other braided line besides Summit hose? I guess I will have to start over with new hose ends. Do all the hose ends for the Nylon braided line crimp on or do they look like the pic. I posted above? On the Summit web sight they do not say which ends go with each hose..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Braided fuel questions.......... [Re: D-50] #1579351
02/18/14 01:37 AM
02/18/14 01:37 AM
mt. pleasant, PA
Diplomat440 Offline
Happy Birthday Diplomat440  Offline
mt. pleasant, PA
I just put some lines together with Aeroquip startlite black hose with Summit ends
It was my first time using braided hose of any kind, was very easy to work with and seemed like the hose and ends were compatible
[image]http:// [/image]
Re: Braided fuel questions.......... [Re: D-50] #1579352
02/18/14 03:32 AM
02/18/14 03:32 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I got my fittings through Pettis and they`re not all earls fittings and they all work fine cos the nylon is thinner than the stainless and presses in real nice and easy.
Re: Braided fuel questions.......... [Re: Thumperdart] #1579353
02/18/14 09:35 PM
02/18/14 09:35 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Thanks for all the help maybe I can get figured out. I guess I will order some of the parts tonight.
Re: Braided fuel questions.......... [Re: D-50] #1579354
02/19/14 02:16 AM
02/19/14 02:16 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Don't forget the hose cutters,they make life so much better and almost eliminates the BLEEDING
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Braided fuel questions.......... [Re: hemi-itis] #1579355
02/19/14 02:30 AM
02/19/14 02:30 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I use pvc cutters............... Just saw "bleeding" ya, no more stainless braided for me and of course the pvc cutters don`t work on that stuff but it`s excellent and quick on the nylon.
