Braided fuel line questions.......... #1579329
02/15/14 06:05 PM
02/15/14 06:05 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I am upgrading my whole fuel system and I do not have any experience with any kind of braided line. Do the stainless and nylon braided line use the same kind of fittings on the end of the hoses. I may end up using stainless and nylon. I like the look of the black line better than the stainless and I already have some fittings but I will need to get more. I am going to a 1050 carb and I already have a MagnaFuel pump and a Holley billet regulator, I just got to plumb everything.Thanks for any help or suggestions.....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Braided fuel questions.......... [Re: D-50] #1579330
02/15/14 06:08 PM
02/15/14 06:08 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Run the black. It's easy to assemble, no metal spintering and it works the same.
And it's much lighter too.
Re: Braided fuel questions.......... [Re: Sammy] #1579331
02/15/14 06:27 PM
02/15/14 06:27 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
The fittings are generally not interchangeable between hose types. I like the Teflon lined hose myself as it lasts forever and doesn't have rubber to breakdown with age.
Re: Braided fuel questions.......... [Re: Quicksilver440] #1579332
02/15/14 07:02 PM
02/15/14 07:02 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I have the magnafuel 500 pump and it is for -12 fittings. I want to run -10 from the pump to the regulator. Would you run -12 or -10 from the fuel cell to the pump.
Re: Braided fuel questions.......... [Re: D-50] #1579333
02/15/14 07:07 PM
02/15/14 07:07 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
-12an from cell to inlet of the pump and then -10an from outlet of pump to inlet of fuel regulator.
Re: Braided fuel questions.......... [Re: D-50] #1579334
02/15/14 07:08 PM
02/15/14 07:08 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
I always go one size bigger from the cell to the pump, than from the pump to the regulator. So if you're using 10 to the regulator, go with 12 from the cell to pump.
Re: Braided fuel questions.......... [Re: PLUM BAD] #1579335
02/15/14 07:48 PM
02/15/14 07:48 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I was looking at the -12 Summit brand Braided Nylon hose and all the fittings for the end of the hose say -12 AN hose to male NPT. Why do they not have -12 an to female -12 an. I do not need the npt end unless that what goes into the fuel pump. I am totally lost with the braided hose.
Re: Braided fuel questions.......... [Re: D-50] #1579336
02/15/14 07:58 PM
02/15/14 07:58 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
inlet and outlet from the pump are -12AN MALE you'll need a -12an to -10an O ring male reducer for pump.
Re: Braided fuel questions.......... [Re: Sammy] #1579337
02/15/14 08:08 PM
02/15/14 08:08 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
That is what I thought but for the braided nylon hose it only shows the fittings with the NPT on one end. Are the fittings for the stainless and nylon braided hoses different?
Re: Braided fuel questions.......... [Re: D-50] #1579338
02/15/14 08:49 PM
02/15/14 08:49 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
No get the Russell black hose with blue tracer and get the Summit fittings. They work great in combination with each other.
Re: Braided fuel questions.......... [Re: Sammy] #1579339
02/15/14 08:54 PM
02/15/14 08:54 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Here's your pump inlet and outlet fittings. sold as a pair. This should get you started.
http://www.summitracing.com/parts/mrf-mp-3614/overview/
Re: Braided fuel questions.......... [Re: Sammy] #1579340
02/15/14 09:10 PM
02/15/14 09:10 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Thanks I just put the fittings you showed me in my summit cart. Will the summit hose ends work with the Russell black hose?
Re: Braided fuel questions.......... [Re: D-50] #1579341
02/15/14 09:18 PM
02/15/14 09:18 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
yes they are the easiest to use. just spray wd40 into the hose prior to tightening down on the threaded part of the fitting and make sure you blow out the hose prior to attaching everything to the regulator and carbs.
Re: Braided fuel questions.......... [Re: Sammy] #1579342
02/15/14 09:19 PM
02/15/14 09:19 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Fragola fittings are an excellent choice too.
Re: Braided fuel questions.......... [Re: Sammy] #1579343
02/15/14 09:26 PM
02/15/14 09:26 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Thanks for the help ... T&T starts in 2 weeks and I would like to get most of this done. I might run like it is now first then upgrade fuel system to see if it makes any difference. I am running a mechanical pump on the motor now with 3/8 rubber hose and Autozone $2 fuel filter.
Re: Braided fuel questions.......... [Re: D-50] #1579344
02/15/14 10:17 PM
02/15/14 10:17 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Pass on the Summit large fittings. I just tried 2 new summit ones on my -12 AN Russell hose and it doesn't work well. Impossible to attach due to the hosebarb end. Use the Fragola stuff all the way around. Summit must have changed vendors or something.
Re: Braided fuel questions.......... [Re: Sammy] #1579345
02/16/14 09:48 PM
02/16/14 09:48 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Does anyone know if any of the nylon braided hose use this type of fitting? I noticed some of them use a crimp on fitting and I rather not use that kind.I was wanting to go nylon braided instead of stainless. I already have some of the fittings in this picture.
Thanks..
Re: Braided fuel questions.......... [Re: D-50] #1579346
02/16/14 10:33 PM
02/16/14 10:33 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That looks similar to mine w/Earls nylon line.................
Re: Braided fuel questions.......... [Re: Thumperdart] #1579347
02/17/14 10:37 PM
02/17/14 10:37 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
Thumper are you using the Earls PRO-Lite 350 nylon hose? I have not decided what to use yet.
Thanks...
Re: Braided fuel questions.......... [Re: D-50] #1579348
02/17/14 10:53 PM
02/17/14 10:53 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Each line has specific fittings for them, they are mostly 37* with others types being JIS and SAE 45*. You need to find the right fittings per the hose. Aeroquip and stratoflex have interchangeable ends, but most others are not made to the same standard. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
