Which 950 carb? #1578487
02/13/14 04:27 PM
02/13/14 04:27 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
I'm looking to buy a new carburetor this race season and wanted opinions on these 2.
1. Bigs stage 5 950dp carb, currently on sale for $500.
or...
2. Proform 950dp carb (about $630).
Any opinions, experiences, pros/cons with either would be great. This is going on my 410 small block listed in my sig. Thanks!
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Which 950 carb? [Re: FlyFish] #1578488
02/13/14 04:38 PM
02/13/14 04:38 PM
SoCal
Brian Hafliger Offline
SoCal
I like the new Ultra 850HP carb. If it's a mild build, you might consider the std. 950HP.
Brian
Brian Hafliger
Re: Which 950 carb? [Re: FlyFish] #1578489
02/13/14 04:42 PM
02/13/14 04:42 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
What do you have now?
Also, don't get tripped up by how many different "950" carbs there are out there. CFM ratings for carbs aren't necessarily consistent w/ how they're labeled and what's a better point of comparison are venturi ID, throttle plate size and booster type.
Re: Which 950 carb? [Re: Brian Hafliger] #1578490
02/13/14 04:44 PM
02/13/14 04:44 PM
Central NC
gch Offline
gch  Offline
Central NC
Bigs redid my 850dp and it worked great.It now sits on the shelf since I switched to a 950 vacuum secondary.
Re: Which 950 carb? [Re: BradH] #1578491
02/13/14 05:29 PM
02/13/14 05:29 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Currently I have a "750dp"...it started life as a 650dp, I added a 750 Proform main body. It works well, just always wanted to see if a 950 will pick it up a little. One of my buddy's at the track with a similar engine had a race Demon carb, switched to a 950 and it ran exactly the same...so idk, it might help, it might not.
Re: Which 950 carb? [Re: FlyFish] #1578492
02/13/14 06:15 PM
02/13/14 06:15 PM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Borrow your buddies carb before buying one.
But, Jesse Biggs did a 850 for me, and it runs great. I need a bigger one myself, but too cheap to get one.
Re: Which 950 carb? [Re: Dodgeguy101] #1578493
02/13/14 06:36 PM
02/13/14 06:36 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I had a bigs 950, I would highly reccomend it!
Re: Which 950 carb? [Re: Joshs68] #1578494
02/13/14 06:44 PM
02/13/14 06:44 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
We used a Pro Form 950 OTB and picked up almost 2 tenths over a H 850dp I think which ever you get a better deal on..they are both good..it's on a 512 stroker
Re: Which 950 carb? [Re: dynamite] #1578495
02/13/14 06:58 PM
02/13/14 06:58 PM
Renton Washington
Triple Threat Offline
Renton Washington
My old motor, the 390 which ran a touch slower than yours does, but in a heavier car, was maybe .03 faster with a 1000 AED on it over a 750HP and maybe .5 MPH. There wasn't a lot of difference.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Which 950 carb? [Re: Triple Threat] #1578496
02/13/14 09:29 PM
02/13/14 09:29 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
I should probably start this in its own thread, but there was a third option I was considering....Converting my current carb to e85 using this kit from Rob Mix:
http://www.ebay.com/itm/750-850-950-1050...000&vxp=mtr
Has anyone had any experience with this conversion? Pro's/cons? This is on a 10.9:1 compression motor. Any better ET gains switching to e85?
Re: Which 950 carb? [Re: FlyFish] #1578497
02/13/14 09:33 PM
02/13/14 09:33 PM
Renton Washington
Renton Washington
https://board.moparts.org/ubbthreads/show...mp;Main=7737868
Talk to AJ, He can convert your current carb for you, or sell you a kit to do it yourself.
-Dustin
Re: Which 950 carb? [Re: Triple Threat] #1578498
02/13/14 10:53 PM
02/13/14 10:53 PM
Indy
FlyFish Offline OP
FlyFish  Offline OP
Indy
Thanks Dustin for the link. I remember reading this thread a while back. I'll look AJ up and see what he suggests for my car .
