How to do..assemble rear 8 3/4? #1578317
02/13/14 09:41 AM
02/13/14 09:41 AM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
I have most of my parts, narrowed hsg, 742 center sect complete (non posi), narrowed axles. Do i need to make sure the ends are tuftrifted sp?
Need advice to make sure its correct
Re: How to do..assemble rear 8 3/4? [Re: 36dodge] #1578318
02/13/14 10:55 AM
02/13/14 10:55 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Re: How to do..assemble rear 8 3/4? [Re: 36dodge] #1578319
02/13/14 03:52 PM
02/13/14 03:52 PM
When you say "narrowed axles did you have the stock alxes cut and resplined? If so ask the company you had do them about having them reheatreated I'm almost sure that they will say don't do it, run them the way they are I've never had a stock axle narrowed, I always bought new custom made ones Good luck, let us know what you decide to do
Re: How to do..assemble rear 8 3/4? [Re: Cab_Burge] #1578320
02/13/14 04:05 PM
02/13/14 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory spline ends were case hardened; more for wear than torsional strength.
Re: How to do..assemble rear 8 3/4? [Re: Cab_Burge] #1578321
02/13/14 04:18 PM
02/13/14 04:18 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I had an axle (only one of the 2) on my latest Dana 60 project cut and resplined. I went to a driveline shop with the pinion yoke so that he could identify it before I brought in the driveshaft to be shortened. So I told him about my project and he told me that the Q&D method of testing for hardness on the recut splines is to take a file and run it across them, if it digs in it is too soft and will need a reheat. If the file skips across the splines it is good to go. And that is the case with my axle
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: How to do..assemble rear 8 3/4? [Re: Polarapete] #1578322
02/13/14 04:46 PM
02/13/14 04:46 PM
Commando1 Offline
Commando1  Offline
You don't learn that from a book.
I gotta remember that one.
Re: How to do..assemble rear 8 3/4? [Re: 36dodge] #1578323
02/13/14 11:18 PM
02/13/14 11:18 PM
NH
3
36dodge Offline OP
36dodge  Offline OP
NH
What are some tips putting this thing together?
Re: How to do..assemble rear 8 3/4? [Re: 36dodge] #1578324
02/14/14 02:31 AM
02/14/14 02:31 AM
Get a factory service manual made for 1973 and earlier Mopar E bodys and follow its recommendations for setting the third member up and the rest of the rear end assembling Sometimes it is better to pay someone else to do what you don't know how to do for yourself, kinda like brain surgery AKA, it is very easy to mess up a gear set by not getting it set up properly to start with, trust me on that, I've learned that lesson already
Re: How to do..assemble rear 8 3/4? [Re: 36dodge] #1578325
02/14/14 09:47 AM
02/14/14 09:47 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Buy the book linked above, buy the FSM, rear both till you understand it generally, then ask for tips. Right now you don't know enough to know what to ask.
Only tip you got that you can use right now is to pay someone else to do it.
Don't be the exception.
Re: How to do..assemble rear 8 3/4? [Re: Commando1] #1578326
02/14/14 10:55 AM
02/14/14 10:55 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Sounds like the gears are setup and ready to drop in.If thats the case assembley is pretty easy.Worst part would be installing the seals for the axles.Rocky
Chrysler Firepower
Re: How to do..assemble rear 8 3/4? [Re: therocks] #1578327
02/14/14 10:59 AM
02/14/14 10:59 AM
Commando1 Offline
Commando1  Offline
THUS....
He needs the book.
Re: How to do..assemble rear 8 3/4? [Re: Supercuda] #1578328
02/14/14 11:00 AM
02/14/14 11:00 AM
Commando1 Offline
Commando1  Offline
Thank you........
