Barracuda transmission color? #157830
11/27/08 05:24 PM
11/27/08 05:24 PM
Toledo Ohio area
69fishes Offline OP
69fishes  Offline OP
Toledo Ohio area
I have a 69 340-S with a matching numbers 833 4-speed transmission. What color was the trans from the factory? I believe that the car that I am working on is a virgin vehicle. When disassembling it for restoration the trans was painted motor color blue. Is that correct?
Re: Barracuda transmission color? [Re: 69fishes] #157831
11/27/08 06:31 PM
11/27/08 06:31 PM
ronj Offline
ronj  Offline
I believe that is correct my 69 340 4 speed was painted blue same as motor.
Re: Barracuda transmission color? [Re: ronj] #157832
11/27/08 10:28 PM
11/27/08 10:28 PM
Toledo Ohio area
69fishes Offline OP
69fishes  Offline OP
Toledo Ohio area
Thanks for the information on the color. Mine looked like it was painted after it was assembled with the engine.It will be blue when it goes together
Re: Barracuda transmission color? [Re: 69fishes] #157833
11/27/08 10:44 PM
11/27/08 10:44 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Are the A-bodies different? The E and B's seem to be natural colored. Or mostly natural with just some overspray on the front of them.
BTW This should be in the Resto section.
