Page 10 of 22 1 2 8 9 10 11 12 21 22
Re: Let the Hemi swap begin [Re: AlexP] #1577519
11/16/14 10:28 PM
11/16/14 10:28 PM
Melbourne.....Oz-land
Moparmal Offline
Moparmal  Offline
Reason I asked is I missunderstood your earlier comment about the biscuit mount.
So did u use the TTI adapter mount brackets?. -,most everyone who uses them has had grief......
Re: Let the Hemi swap begin [Re: Moparmal] #1577520
11/16/14 10:32 PM
11/16/14 10:32 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I used TTI mounting brackets with a stock biscuit rubber mount on the passengers side and a solid Moroso mount on the drivers side. I was fortunate and they didn't cause me any issues.
I had my engine on the hoist and bolted in the chassis in under 30 mins.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: AlexP] #1577521
11/17/14 12:39 AM
11/17/14 12:39 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Okay, is it done yet? It's been more than 7 hours since the last time I asked. Surely that's long enough.
- Stu Harmon
Re: Let the Hemi swap begin [Re: feets] #1577522
11/17/14 12:55 AM
11/17/14 12:55 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Kevin, is that you? I thought you might have fallen into one of those bottomless pits you call cylinders..
Re: Let the Hemi swap begin [Re: AlexP] #1577523
11/17/14 02:19 AM
11/17/14 02:19 AM
Moparmal Offline
Moparmal  Offline
Makes me wonder if the adapters were configured on a B Body K frame....that might account for why the A Body guys have issues...
Re: Let the Hemi swap begin [Re: Moparmal] #1577524
11/17/14 12:16 PM
11/17/14 12:16 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Entirely different part numbers.
Please stop trying to make every 3rd gen Hemi thread about your grievance against TTI. They're the best we've got. Instead of complaining about their product, start sharing information on how to make their products work, because they do for about 90% of the guys doing the swap (sorry Mal and Kevin- I know y'all both had nearly insurmountable issues).
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577525
11/17/14 08:36 PM
11/17/14 08:36 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I think you read my mind as I was reading the updates on this thread.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577526
11/18/14 02:10 AM
11/18/14 02:10 AM
Moparmal Offline
Moparmal  Offline
That's some pretty unfair accusations Wade...and if its because you're trying to keep the thread OT....its NOT the way to do it.
I don't want to ruin this thread....but think on this:
1......I didnt use TTI headers so why should I care
2.... The "other thread" was all about conversion issues.....so where's the crime?
3. .....My comment on this post is all about research...not bagging out TTI..so be cool!
Just trying to find out why they work for some and not others.
I noted that Alex didn't use the TTI drivers side adapter.....perhaps if he had...we could have discussed it further....
What DOES get my back up is the sense of disbelief I get whenever I post about the damn mounts.....there seems to be a bit of "It didn't happen to me.... so it doesn't happen" bs attitude going on......
Edited a couple of times to keep it brief...
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577527
11/18/14 07:33 AM
11/18/14 07:33 AM
Moparmal Offline
Moparmal  Offline
That's the milodon peice for the dipstick and it's just the normal pan. 7 quarts? Weve determined that the road race pan probably isn't needed for what I want to do, even with sticky tires.
31000 listed as 6 quart. I run up to 7-ish. I log oil pressures and haven't had an oil pressure drop.
The 31003 RR pan is listed as 7 quart.
Moving on ....
What do you spin yours up to Wade...I'm wondering if mine will be OK to 7100 without an accumulator......
Re: Let the Hemi swap begin [Re: Moparmal] #1577528
11/18/14 09:13 AM
11/18/14 09:13 AM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Moving on ....
I spun the forged 5.7 to 7,000+. With accumulator. 10+ seconds at 7,000+ WOT.
I didn't spin the 6.1 over 6500. That was being overly cautious.
I would recommend an accumulator. Cheap insurance. Hemi Joe ran his dry early on at the track if I remember correctly- in the 7500 rpm range maybe?
The modern Mopar thread we had on oiling had more info on the subject, including that the drag pak guys run 11.5 quarts between their pan (8 qt) and accumulator (3 qt). Without the accumulator they were running dry at high rpm. With the accumulator they're turning 8,300-8,500.
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577529
11/18/14 10:04 AM
11/18/14 10:04 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Mal, I'm using the TTI motor mounts. I'm also using the factory style insulators, but one side is a Moroso solid mount. That is the the only exception.
That has nothing to do wth the Hemi. I would use the same factory insilator and Moroso mount with any SB or BB
Re: Let the Hemi swap begin [Re: AlexP] #1577530
11/18/14 02:25 PM
11/18/14 02:25 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Mal,
Please look at both of these pictures.
The first one shows a factory rubber insulator mount with the "nub" on it. That's what caused me grief on the passengers side. You can clearly see it attached to the black TTI plate.
On the drivers side, take note of the silver mount with the pass through bolt holes. That is a solid Moroso mount that fits SB/BB for this style of engine mount. It was my alternative to running expensive engine mounts. It did not impair my install at all.
The TTI mounts are excellent in my opinion. For my application they were as good or better than my factory BB pieces.
Re: Let the Hemi swap begin [Re: AlexP] #1577531
11/18/14 11:09 PM
11/18/14 11:09 PM
Moparmal Offline
Moparmal  Offline
1st - Thx Uhcoog for the advice - looks like an accumulator for me...especially if I go to 4.11s
Next - Alex/Wade.....You arent gonna believe this......
......wait for it......
I have the left side (Ur drivers side) adapter mounted HORIZONTAL to the block.....not vertical like yours!!!!
Can they be be attached either way?
What gives???? LOL!!!....
.. (Other than Im an idiot I mean? )
Re: Let the Hemi swap begin [Re: Moparmal] #1577532
11/19/14 12:52 AM
11/19/14 12:52 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
Thanks to everyone for the info on the motor mounts, seems like that was one thing that was not clear to me.....
Re: Let the Hemi swap begin [Re: Moparmal] #1577533
11/19/14 12:59 AM
11/19/14 12:59 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have just lost all respect for you now Mal.....
Mopar to the bone!!!
Re: Let the Hemi swap begin [Re: feets] #1577534
11/19/14 01:01 AM
11/19/14 01:01 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Need to change the title of this thread to
"Let the Hemi swap take 4 EVAR!!"
Re: Let the Hemi swap begin [Re: 72Swinger] #1577535
11/19/14 03:58 AM
11/19/14 03:58 AM
Moparmal Offline
Moparmal  Offline
Don't crow too soon!! LOL!!
How come mine is a completely different animal??
Re: Let the Hemi swap begin *DELETED* [Re: Moparmal] #1577536
11/19/14 04:35 AM
11/19/14 04:35 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You have an A body mate.
Re: Let the Hemi swap begin [Re: 72Swinger] #1577537
11/19/14 04:45 AM
11/19/14 04:45 AM
Moparmal Offline
Moparmal  Offline
....Oh good grief...suddenly my head hurts...a lot!
Sp weve been comparing completely different parts........:groan:.... And I destroyed Alex thread for nothing....
Sorry folks
Re: Let the Hemi swap begin [Re: AlexP] #1577538
11/19/14 08:53 AM
11/19/14 08:53 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
This thread is very inspiring. Too bad I'm in the middle of a stroker build.
Just have a stock 18 spline transmission going in? I searched the thread, but didn't see that info.
