Re: Let the Hemi swap begin
[Re: haddixj]
#1577379
02/22/14 04:24 AM
02/22/14 04:24 AM
Posts: 10,645 Houston, Tx
AlexP
Houston, Tx
I wonder if EFI source would build a system out of the new MS pro? That unit is designed to be able to get wet and mount in the engine compartment. I really like the kit form of MS that has come out. That should make it alot more popular with people
The MS3 Pro is over hyped IMHO. It's more expensive and doesn't have the built in coil drivers. Yes, it can get wet but thats about the only upside.
[Re: AlexP]
#1577381
02/22/14 03:33 PM
02/22/14 03:33 PM
Posts: 841 Santa Fe Springs, CA
Dan@Hotchkis
I'm not one of those people to care about having ford or chevy parts on a mopar, but I can't see why someone would spend $2000 to have LS1 stuff on their car when there are better and cheaper options out there...unless you identify with the reasons I stated above.
Holy smokes, I didn't know that guy was asking that much for the kit. I was going to call him Monday for pricing info.
[Re: Dan@Hotchkis]
#1577383
02/22/14 04:53 PM
02/22/14 04:53 PM
AlexP
Houston, Tx
I don't feel that using a factory ecu and designing a reluctor wheel justifies that price. Just my .02.
[Re: AlexP]
#1577385
02/23/14 10:33 PM
02/23/14 10:33 PM
moparpollack
Lil Herman
Lil Herman
85086
I've been dying to update progress on my swap from a Big block to a 3G Hemi.
I had a perfectly fine running 69 HP 383 with 915HP heads, a DP4B/650DP, HP Manfiolds and a 4 speed with 3.23's. I drove it like that for about 1000 miles and it bored me. The combo that I thought I wanted and I'd always dreamed about. I didn't like it for the type of driving that I do.
So, I pulled the 383 and parted all my big block stuff on Craigslist and on here. Sold all of it for a fair price and decided that it was time for a new hemi. I was just upset with bent pullies, leaky valve covers and general old car quirks.
I worked from 2006-10 for a shop that worked on and modified the LX Hemi cars, so I know my way around them quite well. I fell in love with the powerplant in a 4700lb station wagon, so my 3600 lb B-body would be ridiculous fast with just a simple head and cam 6.1. I started with just a bare 6.1 block. Literally nothing else at first. I knew about what I wanted, and I had really big dreams at first. I was looking to build a motor that would compliment all the handling stuff that I've done to the car.
-1.24" T bars -Koni Red Shocks -AndyF's LCA plates -Tubular UCA's (Coming off now...) -New bushings and Poly where I could -Firm Feel Firmer than stage 3 box from Dick -11.75" with Firm Feel Carbon Metallic Pads
I ran without sway bars, so a set of fresh leaf springs and F&R Hotchkis or Hellwig sway bars are about all I need to complete the suspension to where it needs to be. All of the above made the car feel amazing, even in it's incomplete state.
I started my motor build parts gathering a few years ago and it all started with a $300 6.1 block that I was going to build a 426 or forged 6.1 out of. I quickly realized that I didn't need that much motor, so after some horsetrading with my friend uhcoog1 (wade) I ended up with a stock bore 6.1 in great shape. I picked up a stock set of 6.1 rods and pistons and started my process of building up a mostly stock 6.1 shortblock. Nothing fancy except for a set of stock rings opened up a little bit to keep the pistons from breaking the ring lands (a common 6.1 issue). Otherwise, the whole motor is stock spec with no after market parts aside from the valve springs (PAC) and the Comp Camshaft.
Here is the motor buid
4.055x3.580 6.1 Stock pistons/new rings Stock Powdered metal rods with new Chrysler rod bolts (Same as 8.4 viper) King Bearings Stock 6.1 Timing set and tensioner Melling Oil pump Jeep SRT8 Oil Filter Adapter Frank Racing 219/231 .585/.585 112LSA GTP ported 5.7 2009+ Eagle Cylinder heads with PAC 1220 Springs. These are a closed chamber heads and will net 11:1 CR with my stock shortblock. More than do-able with 93 octane all day long Stock 6.1 Intake Manifold with BBK 80mm tb SRT4 Stage 1 43lb injectors Stock 6.1 fuel rail TTI 1 3/4 Headers to a 2.5" H pipe system with turbo mufflers Lakewood Bellhousing from a SB MP/Mcleod Hemi 10.5 Conversion Flywheel Sachs Diaphragm 10.5 stock clutch TTI Motor mount brackets with a solid and rubber mount on either side Mildon Oil Convesion oil pan
It's a bit scary to me how stock and simple this motor is. Nothing fancy at all.
I've just purchased the Megasquirt MS3X kit from Mike @ www.efisource.com as of yesterday and I'm really looking forward to running his system. It is the first kit to come out for a 3g hemi that is a refined harness that is based on megasquirt.
The electronics portion of this build will be a copy of the fuel system that uhcoog1 has on his road race duster. So simple yet it more than makes up for the fact that I'm still running a stock fuel tank. If he can't run out of fuel on a roadcourse, then anyone on here will be fine.
My fuel system will be the following Carter 4601HP pump (ran both my 383 and 440 with a carb previously) BCBroncos Accumulator to act as a resivour/surge tank. Walbro GSL392 Inline pump Corvette Fuel/Filter Regulator by Wix.
The car already had 1/2" feed and return lines in stainless with a 1/2" stock style pick up that I added a 1/2" return to, so my fuel system is ready for whatever I can throw at it with just a pump change.
Over the next few weeks I'm going to detail my engine build and install for everyone to see.
I'd like to eventually do up a website to help inform people about the process of putting this new style of motor into a classic mopar. I had a cardomain website a long time ago, and I'd like to do it one better.
http://www.cardomain.com/member/themoparkid/
The goal for me is to have a fair weather daily driver that I can hop in and knock out 300 mile day trip while maintaining above average fuel mileage, not smelling like fuel (its a real problem), being able smile from the speed and being able to have a road course worthy classic Mopar.
Here are some already shown pics of my car...
So far, I'm most of the way there.
So us the money for the controller and the fuel system !
How much is this system going to run?
[Re: Uhcoog1]
#1577386
02/24/14 02:16 PM
02/24/14 02:16 PM
AlexP
Houston, Tx
Does the VVT driver on this properly control the cam phaser on '09 up engines or is it pretty much just fluff? That would make this a very good prospect in that area. If not maybe it could be used for MDS since that functions similar to VVT. Not that I am concerned with that.
The box has the capability to control VVT, etc, but AFAIK, no one has done that or even tried to with a Hemi yet.
same with the knock control...
What wade said.
Just because it is there, doesn't mean it is compatible with the hemi...yet. There are always expansions looming over the horizon.
And I'm less than $1500 for EFI and fuel system.
The fact that gets me everytime is when someone says they want to save money by going carb on a motor like this.
Even if you have nice carb, the MSD ignition controller is still $800 and then you may or may not have to do anything with your fuel system.
[Re: AlexP]
#1577387
02/24/14 02:42 PM
02/24/14 02:42 PM
Posts: 52 CO
Twisted
CO
Not knocking the system at all. I was just surprised to see it listed on the HEMI specific box as I hadn't heard that anyone figured it out. I hope someone figures it out before I am to that point. I was leaning towards the LS comp only for the fact that if I am 2000 miles away from home and new one is just a junkyard away and a flash from the laptop.
Thank you Aaron
69 Dodge Polara 4DHT 70 Plymouth Duster 03 Dodge Neon R/T 05 Dodge Grand Caravan SXT
[Re: Twisted]
#1577388
02/24/14 04:30 PM
02/24/14 04:30 PM
AlexP
Houston, Tx
My friend shorted his MS3 box by accident and he had it turned around in about a week with the repair.
You've got a valid point, but I wonder if the ECU they sell for the LS is flashed to be open source and includes softare to tune yourself, or if you still need HP Tuners or EFILive to change things.
[Re: feets]
#1577391
02/24/14 09:16 PM
02/24/14 09:16 PM
AlexP
Houston, Tx
I wouldn't consider an ECU from a wrecking yard - if the car was in any accident, the ECU will be locked in limp mode, which in our case required a replacement. HP tuner software can't reset it
Strange.
We've done several Hemi cars and none of them required ECU replacement. Perhaps yours took a different kind of hit.
He is reffering to the LS1 Delphi based EFI kit that Nutter Racing is offering for the 3G Hemi Swap.
I've had static kill one Hemi Ecu, but that was completely the installers fault. Got a good zap and killed the logic that was flashed.
[Re: AlexP]
#1577392
02/24/14 09:31 PM
02/24/14 09:31 PM
Posts: 553 Sac, CA, USA
ntstlgl1970
Sac, CA, USA
Strange.
What Alex said - was an LS ecu
[Re: AlexP]
#1577394
02/25/14 04:41 PM
02/25/14 04:41 PM
AlexP
Houston, Tx
Also, I hate my taxi cab dash. It's never worked and when I went with Painless wiring in the car I never even bothered hooking it up. I was about to wire a bunch of auxillary gauges to keep tabs on things, but I'm not doing that any longer. I'm going to use Shadow Dash MS for my temp, pressure, voltage, rpm, warning lights and Speedo. All of which will show off of my MS3 box. I might be able to get my fuel sending unit to be read by the MS3 box. I'm just going to make a nice magnetic mount for the Android Device of my choice (Nexus 7 most likely) and use that for the near future. If I leave the car unattended, I'll hide it or put it in my pocket. This is a Galaxy S3 in a 68 Chevelle. Youtube Video Link to MSextra thread
