Page 2 of 22 1 2 3 4 21 22
Re: Let the Hemi swap begin [Re: AlexP] #1577359
02/20/14 01:52 AM
02/20/14 01:52 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
The fuel injection made it in yesterday. It would have been here faster, but USPS tried to deliver to a business on Saturday. No big deal.
My initial impressions are very good. The build quality of this box is almost on par with an XFI box. Great connectors that give a rewarding pop from vacuum when you disconnect them, heavy gauge wiring with good insulation and quality connectors.
For $1300 this kit far exceeds my expectations. The simple fact that something as capable as MS3 is housed in this box, makes it an unbeatable deal.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: AlexP] #1577360
02/20/14 01:53 AM
02/20/14 01:53 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
An overall shot. The harness is very well laid out and it uses OE connectors.
Re: Let the Hemi swap begin [Re: AlexP] #1577361
02/20/14 01:55 AM
02/20/14 01:55 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Here are the 6 wires that it needs to run...off the top of my head it is Fuel pump, constant 12v, switched 12v, o2 etc...
This may be easier to get working for me than a 6AL....no joke.
Re: Let the Hemi swap begin [Re: AlexP] #1577362
02/20/14 03:01 AM
02/20/14 03:01 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Looks good! Where can you mount it? Can you put a pop can or a $1 bill next to the box for size comparison?
Mopar to the bone!!!
Re: Let the Hemi swap begin [Re: 72Swinger] #1577363
02/20/14 10:30 AM
02/20/14 10:30 AM
Wildwood, FL
1fastabody Offline
1fastabody  Offline
Wildwood, FL
Does this system run your fuel injection and the ignition? Also is it fully programmable from a laptop? It looks like a really nice setup. I would be very interested in one if it does all that.
Re: Let the Hemi swap begin [Re: 1fastabody] #1577364
02/20/14 11:12 AM
02/20/14 11:12 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'll get some good pictures tonight or in the morning.
This runs it all. Fuel and spark. No external modules or extra stuff. It comes with about 15 extra wires for boost control, nitrous etc but none are critical to the n/a functions.
Re: Let the Hemi swap begin [Re: AlexP] #1577365
02/20/14 12:04 PM
02/20/14 12:04 PM
GA
roadrunninMark Offline
GA
The Deane guy from the Hot Rod article used the unisteer rack set up. I thought that had a bad review?
Re: Let the Hemi swap begin [Re: roadrunninMark] #1577366
02/20/14 12:21 PM
02/20/14 12:21 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
It does, but when you look at the cutting they had to do to the steering box mount, it may not have worked any other way with his combination of components.
Re: Let the Hemi swap begin [Re: TC@HP2] #1577367
02/21/14 10:36 PM
02/21/14 10:36 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I can't speak for his choice of parts, but I like bolt in parts for my car. The ease of install for this motor and the relative ease of the EFI will be great.
By far, the most complex part of the car (I use that term loosely...its not really complex) is the fuel system.
Carter P4601HP for my lift pump. I ran it as a single fuel pump before and it doesn't have a problem pulling fuel from the bottom of the tank.
Feeling into the BCBroncos Fuel Accumulator. This will give me a 1qt reservoir of fuel at all times. This was a big part in making this car effective without a full race fuel tank or a heavily modified stock style tank. Its just a very affordable surge tank, props to wade (uhcoog1) for giving me this idea...
A simple GSL392 Rotary vane inline external fuel pump. Good for 600hp all day long.
A corvette fuel filter/fuel filter regulator. About $27 by wix, and keeps my engine bay clean by leaving all the extra plumbing back there.
This will go up front through my 1/2" stock style fuel lines in stainless. I'm going to be blocking off my return line for now, it's not needed at the moment.
I'll be feeding into a set of stock 6.1 fuel rails. Nothing fancy. Good for 600+ hp. KB retains these for their 2.8L blower kits.
And finally a set of SRT4 stage 1 fuel injectors.
Here is a breakdown of what hemi injectors will do...
Stock 5.7- Bolt ons on a 5.7
Stock 6.1- Maxed out on a head and cam car
Stock 6.4- +1 for a head and cam 6.1, not a huge improvement.
SRT4 stage 1- Entry level max effort 6.1 and basic 426. Also suitable for stock displacement with a small forced induction build (vortech includes these with entry blower kits)
SRT4 stage 2- Built 426 with small nitrous or boost.
Above that, you can get any of the above rebuilt from any number of vendors up until about 1000hp. After that, something like Injector Dynamics ID1000 or ID2000 is needed to have excellent drive ability with that much power.
I forsee my car getting a second GSL392, a forged 6.1 and some sort of forced induction. I've got a Vortech Kit for it, but I really want a Magnuson/Kenne Bell kit..just for the sound really. I'd be happy to lose 100hp over a centrifugal blower for that whine.
Re: Let the Hemi swap begin [Re: AlexP] #1577368
02/21/14 11:49 PM
02/21/14 11:49 PM
Shingle Springs Ca
haddixj Offline
haddixj  Offline
Shingle Springs Ca
Are you planning on going speed density or running a mass air flow sensor? Does the MS3x from them have the map daddy 4 bar sensor? I have MS3X for my chevelle LS swap and the dual map sensor is nice as it can be used to correct for altitude changes by comparing the static one and the engine map sensor. I have heard that the new MS3 Pro uses an external MAP
70 duster 25.1E,73 barracuda, 70 gran coupe, 71 cuda
Re: Let the Hemi swap begin [Re: haddixj] #1577369
02/21/14 11:54 PM
02/21/14 11:54 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
The 3g Hemi is built around Speed Density. I'll be using a factory sensor in the back of my 6.1 intake.
The ECU will make judgements based on the MAP sensor and the intake air temperature sensor. Here is a breakdown of the features on this box.
MegaSquirt MS3
Gen3 Hemi Gold Box Standard features
· Controllers are factory configured for your Gen3 Hemi engine
· Start up program factory installed
· USB, RS232 and CAN communication
· Onboard SD card for Data logging
· 8 High Impedance injector drivers
· 8 High current ignition outputs. No additional boxes or coil drivers needed.
· Fuel pump output
· Fan output
· Stepper and PWM Idle Air Control outputs
· 2 Nitrous outputs
· Variable Valve timing output
· 12 volt tach output
· Two Step Input
· 2 Oxygen sensor inputs
· 2 Knock sensor inputs
· Nitrous input
· Data Log switch
· Dual table switch
· 3 additional general purpose inputs (on/off or frequency)
· 1 additional analog input
Re: Let the Hemi swap begin [Re: AlexP] #1577370
02/22/14 12:32 AM
02/22/14 12:32 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Any pics to depict the size of that thing?
Re: Let the Hemi swap begin [Re: AlexP] #1577371
02/22/14 01:02 AM
02/22/14 01:02 AM
Shingle Springs Ca
haddixj Offline
haddixj  Offline
Shingle Springs Ca
Ok thanks I know some use a GM MAF sensor. The newer card type one is able to read a huge amount of flow and has been succesful with boosted apps.
Re: Let the Hemi swap begin [Re: haddixj] #1577372
02/22/14 01:29 AM
02/22/14 01:29 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline
Good to see another option for our cars. I was just reading up on a kit Mopar Action did an article on a year or so ago. Required the crank to be pulled to install a tone ring. Yikes. However, it allowed the use of GM ECU and all the OBDII diagnostics too...
Now that I see this, I don't know what route I would take.
Re: Let the Hemi swap begin [Re: 72Swinger] #1577373
02/22/14 01:54 AM
02/22/14 01:54 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
7 in x 7 in and the mounting tabs are sliding to allow staggered placement.
Re: Let the Hemi swap begin [Re: Dan@Hotchkis] #1577374
02/22/14 02:00 AM
02/22/14 02:00 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
The only perk I could see that the Delphi based systems have above this is the tuning aspect. There are so many more tuners out there. That being said, if I didn't want to ever tune it myself....I'd be running a hotwire kit with a factory Mopar ECU, get a Diablo Programmer and have someone knock out a tune via email in 3 shots.
Between the autotune function on this (as well as XFI) along with the megasquirt community online, my choice was easy.
I'm not one of those people to care about having ford or chevy parts on a mopar, but I can't see why someone would spend $2000 to have LS1 stuff on their car when there are better and cheaper options out there...unless you identify with the reasons I stated above.
Re: Let the Hemi swap begin [Re: AlexP] #1577375
02/22/14 02:14 AM
02/22/14 02:14 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Thanks, that may squeeze in behind the kick panel. I'm gonna have one in a month or so myself.
Re: Let the Hemi swap begin [Re: AlexP] #1577376
02/22/14 02:14 AM
02/22/14 02:14 AM
Sac, CA, USA
N
ntstlgl1970 Offline
ntstlgl1970  Offline
N
Sac, CA, USA
the datalogging with the ms3 is pretty awesome too which makes tuning that much easier, I'm really impressed with the latest adaptations that have more robust connectors and look more like a "polished" product.
Re: Let the Hemi swap begin [Re: 72Swinger] #1577377
02/22/14 02:30 AM
02/22/14 02:30 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I wanted to mount it in my glovebox but my car leaks....well...like an old car. I'll end up mounting it in a semi-weather proof container somewhere by the AC box.
Re: Let the Hemi swap begin [Re: AlexP] #1577378
02/22/14 03:07 AM
02/22/14 03:07 AM
Shingle Springs Ca
haddixj Offline
haddixj  Offline
Shingle Springs Ca
I wonder if EFI source would build a system out of the new MS pro? That unit is designed to be able to get wet and mount in the engine compartment. I really like the kit form of MS that has come out. That should make it alot more popular with people
