Page 6 of 22 1 2 4 5 6 7 8 21 22
Re: Let the Hemi swap begin [Re: AlexP] #1577439
09/21/14 10:39 PM
09/21/14 10:39 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Starter clearance is great. Better than I was expecting.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Let the Hemi swap begin [Re: AlexP] #1577440
09/22/14 08:59 AM
09/22/14 08:59 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
"Hemi" starter or your normal magnum "mini-starter"? I didn't get a starter with the engine but I do have a magnum starter around.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Let the Hemi swap begin [Re: GoodysGotaCuda] #1577441
09/22/14 10:41 AM
09/22/14 10:41 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
It's a magnum starter.
Re: Let the Hemi swap begin [Re: AlexP] #1577442
09/22/14 11:02 PM
09/22/14 11:02 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Some pictures of the Jeep SRT Oil filter adapter. The shield had to be shortened to avoid the K frame, so I trimmed it a little extra.
Re: Let the Hemi swap begin [Re: AlexP] #1577443
09/22/14 11:02 PM
09/22/14 11:02 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Ground flat and de-burred. One less thing to cut my hand on later on.
Re: Let the Hemi swap begin [Re: AlexP] #1577444
09/25/14 10:36 PM
09/25/14 10:36 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Today I took 1/2" off of the 23 spline input shaft.
Re: Let the Hemi swap begin [Re: AlexP] #1577445
09/25/14 10:37 PM
09/25/14 10:37 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Scribed the whole way around.
Re: Let the Hemi swap begin [Re: AlexP] #1577446
09/25/14 10:38 PM
09/25/14 10:38 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Rough cut...
Re: Let the Hemi swap begin [Re: AlexP] #1577447
09/25/14 10:38 PM
09/25/14 10:38 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Smoothed and hand chamfered...not bad for a greek!
Re: Let the Hemi swap begin [Re: AlexP] #1577448
09/29/14 02:22 PM
09/29/14 02:22 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
A little update:
-My bellhousing alignment dowels pulled out with the block plate. They say that they need 7 ft lb., but clearly I didn't get that much (they were tight...)
-Accessory drive is almost done, just need to add the balancer and PS pump. It was a heck of a time finding the right idler pulley bolt.
-I ground on the mount for the ps side engine mount. I also found my Moroso Solid Mount for the drivers side. No mods needed.
-I bought radiator hoses and they're going to work out pretty well.
Upper radiator hose for passenger side neck:
Dayco C72282 - ID of 1.44 and 1.72 (for a 2006 Dodge Charger 5.7 hemi)
Lower radiator hose for drivers side neck:
Dayco E72281 - 1.44 & 1.66 ID (I measured this one in the store- the water pump side was ~1.5" I think, and the radiator side was smaller) - this is for a 5.7 dodge charger
Thanks to wade for his FABO post on radiator hoses.
Re: Let the Hemi swap begin [Re: AlexP] #1577449
09/29/14 05:48 PM
09/29/14 05:48 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
do you know the main cap bolts are torque to yield?
Re: Let the Hemi swap begin [Re: 70blackfish] #1577450
09/29/14 06:11 PM
09/29/14 06:11 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
They are.
2 uses are about all you get out of them before they undergo plastic deformation and no longer "stretch".
Re: Let the Hemi swap begin [Re: AlexP] #1577451
09/30/14 11:00 PM
09/30/14 11:00 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I cut the back ear off of the ac compressor today.
And also clearanced the k frame for the ac compressor.
Re: Let the Hemi swap begin [Re: AlexP] #1577452
10/04/14 07:30 PM
10/04/14 07:30 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
....and its in!
It fits well. It took some fighting on the biscuit mounts and a little clearancing of the moroso solid mount, but it all fits without issue.
Next up, try and slide the headers in from underneath, bolt on the 6.1 intake and add the oil filter adapter. It will be sealed and I can move onto the fuel system mounting of the additional pump and accumulator.
I have to say, it is a really good looking motor for this car.
A huge thanks to Wade (uhcoog1) for helping me drop it in and being a confidant for all of my tough hotroding decisions lol.
Re: Let the Hemi swap begin [Re: AlexP] #1577453
10/04/14 10:17 PM
10/04/14 10:17 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Easiest Hemi swap so far!
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Let the Hemi swap begin [Re: Uhcoog1] #1577454
10/05/14 01:34 AM
10/05/14 01:34 AM
Santa Fe Springs, CA
Dan@Hotchkis Offline
I'm looking forward to seeing how well everything fits.
Re: Let the Hemi swap begin [Re: AlexP] #1577455
10/05/14 12:11 PM
10/05/14 12:11 PM
mass
K
kotacars Offline
kotacars  Offline
K
mass
Solid mounts would like to hear some feed back on how it feels once running and driving
Re: Let the Hemi swap begin [Re: kotacars] #1577456
10/05/14 12:22 PM
10/05/14 12:22 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'm only running a solid mount on the drivers side, the passenger side is a cheap rubber mount.
Re: Let the Hemi swap begin [Re: AlexP] #1577457
10/05/14 01:59 PM
10/05/14 01:59 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I ran my 318 that way for several years. Seems fine, I kept eating up parts store driver's side biscuits.
2020 RAM 1500
Re: Let the Hemi swap begin [Re: GoodysGotaCuda] #1577458
10/05/14 04:41 PM
10/05/14 04:41 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I'm trying to not break parts and keep this as a low maitnence motor. I didn't have the money for mity mounts or poly locks, but I had one of these mounts left over from the big block stuff. I figured 500hp and a 4 speed might tear up a few things.
