Cam install questions #1577087
02/11/14 12:45 AM
02/11/14 12:45 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
Anyone here run Comp Cams .650/.650 lift solid cam? (pn #23-630-5, 324 dur, lobe sep 108) Do you install it straight up (108)or advance it? What does this cam like? 540 ci RB, 3000 lb A-body, back half car, 4-link, P/G. Only runs 1/8 mile.
Thanks,
Brian
Re: Cam install questions [Re: '72CudaRacer] #1577088
02/11/14 01:13 AM
02/11/14 01:13 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I think that is the cam I have in my barracuda . Computer died so I lost all info. Anyway you better have a high stall converter because it doesn't start running smooth till about 5500. pulls to 7500
Re: Cam install questions [Re: '72CudaRacer] #1577089
02/11/14 01:49 AM
02/11/14 01:49 AM
Nor-Cal
loaderpro Offline
loaderpro  Offline
Nor-Cal
I use Comp cams stuff...286-750, While it is a bit bigger, I used to try and adjust to "the flavor of the week" and at least in my stuff they always ran the best straight up.
Re: Cam install questions [Re: '72CudaRacer] #1577090
02/11/14 03:09 AM
02/11/14 03:09 AM
gregsdart Offline
gregsdart  Offline
That cam has a ton of duration, so I would try 106 to start.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: Cam install questions [Re: '72CudaRacer] #1577091
02/11/14 12:03 PM
02/11/14 12:03 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Thanks,
Brian
That's the old Herb McCandless grind cam. I have used them in the past. They work good in about anything you put them in. I always ran mine +4*=104* intake center line. Really wakes the bottom end up!! I always wanted to go further (102* CL), but never had the motor down to do it. Herb's old philosphy used to be "don't get hung up on duration, stick all the lift you can in there". Comp ground that cam on Herb's specs/reccomendations and they (Herb & CC) sold a BUNCH of them.
If you like drag racing, support your local track.
Re: Cam install questions [Re: '72CudaRacer] #1577092
02/11/14 03:59 PM
02/11/14 03:59 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
tons of duartion power glide 1/8 mile I'd think 104 or 106. But if its like a 6000 stall and big gear that would change things. shift point as well.
Re: Cam install questions [Re: Dodgem] #1577093
02/11/14 04:12 PM
02/11/14 04:12 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
1/8th Mile, I'd want it about 102-103...try to 'use it all up' by the stripe
Unless you got really big high flowing heads and make power way upstairs...then I might go 106....you didn't say anything about heads but with a 540 incher I'm sure your "packin'"
i believe the McCandless stick was based on the small ports and lots and lots of compression...if you've got a (relatively) bad port you try to open that valve as long as you can so "something" can still get in there at high RPM.
The longer the stroke the more closing the valve too late can sometimes work against you, after BDC you start to give up a higher percentage of effective displacement per degree realtive to a same cube motor with a shorter stroke.
WIZE
In Car:
Re: Cam install questions [Re: Streetwize] #1577094
02/11/14 08:23 PM
02/11/14 08:23 PM
Mooresburg, Tn
Mooresburg, Tn
Sorry, I forgot about the heads. This engine runs the cast iron Indy heads, some port work, but not max wedge size. This is the same cam that he has run before, and yes, it does go good.
Thanks,
Brian
