Page 2 of 3 1 2 3
Re: 833 tranny fluid [Re: mopar346] #1576848
02/12/14 12:21 AM
02/12/14 12:21 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
In this thread I have read the downside or possible downside to ATF and Synthetics, so why chance it? No one has mentioned a downside to 80w90 except maybe the cold weather. I have always used gear oil but I cant say I have had any with original fluid and of course most if not all have been from down here.
Ok...you're asking for the downside, I will provide it. 80w90 is fine.....IF its a GL-4, not GL-5 lube, and 95% of the 80w90's available ARE GL-5's.
GL-5 has extreme pressure additives in it, highly desireable in a rear end (ring and pinion). The problem is these additives are not long term compatible with the brass synchros in our 833's.
That's the downside, but many people do use it.
Re: 833 tranny fluid [Re: Pacnorthcuda] #1576849
02/12/14 12:53 AM
02/12/14 12:53 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Since I haven't looked at the GL-4/5 factor is Gl-4 readily available? How about farm use? I've run gear oil in manuals with brass for years with no known issues, of course I am not running them 20k a year either and cant say I have more than 40k on any of them in many years of use.
Careful, your character's showing!
Re: 833 tranny fluid [Re: mopar346] #1576850
02/12/14 01:04 AM
02/12/14 01:04 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Brad Penn
Penn Grade
Pennsoil Gear Plus
Amsoil
Valvoline
All offer 80w-90 in GL-4 grade
Re: 833 tranny fluid [Re: DAYCLONA] #1576851
02/12/14 02:03 AM
02/12/14 02:03 AM
The downside to the early first generation NP833 with the OEM synchors was hard shifting, cold weather or not. ATF help alleviate the hard shifting problems The third generation synchors, 1971 and later versions, help a bunch also I have replaced the early syncho asemblys with the later version along with the steel shifting forks for several customers You can to There are three differrent versions of the NP stock synchro assemblys I've seen, 1964 to 1966, 1967 to 1970 and 1971 and later Two different side covers and two different versions of shifting forks also in those
Re: 833 tranny fluid [Re: Cab_Burge] #1576852
02/12/14 11:36 AM
02/12/14 11:36 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Service manual calls for ATF or Multi Purpose gear lube so pick your poison depending on climate
1969 Hemi Roadrunner 2nd owner
Re: 833 tranny fluid [Re: DAYCLONA] #1576853
02/12/14 12:09 PM
02/12/14 12:09 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
80w-90...end of story IMHO
X2. I drive my Dart until they salt the roads and it's been driven in some pretty cold weather...no problems at all.
Re: 833 tranny fluid [Re: mopar346] #1576854
02/12/14 06:28 PM
02/12/14 06:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
What you have read here is opinion and conjecture.
The weather doesn't have to be all that cold to cause notchy shifting in the 833, the 833 has always had clunky shifting when compared to a T-10 or Muncie. I say give it all the help you can.
Re: 833 tranny fluid [Re: 66HEMICORONET] #1576855
02/12/14 06:35 PM
02/12/14 06:35 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
First time I saw ATF in a manual trans was a 1980 Dodge Aspen...
It came out...
Viscosity...
Windage...
I'll keep gear oil in my gear-driven trans'...
Re: 833 tranny fluid [Re: RSNOMO] #1576856
02/12/14 09:15 PM
02/12/14 09:15 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Clunky shifting?
Not in my experience, but then again my nick name is not spaghetti arms.
Wait, even my daughter who's nickname is spaghetti arms had no problem shifting an A833, with gear oil in it.
Must be you.
Don't be the exception.
Re: 833 tranny fluid [Re: Supercuda] #1576857
02/12/14 09:21 PM
02/12/14 09:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ever driven a T-10? Muncie?
Re: 833 tranny fluid [Re: John_Kunkel] #1576858
02/12/14 09:29 PM
02/12/14 09:29 PM
I use Redline MTL ("manual transmission lube") in my 18 spline and I love the notchieness. I can feel the gears meshing really well. With out that feeling I would describe a tranny shift feeling as "vague". I'll take notchy over vague any time.
Re: 833 tranny fluid [Re: John_Kunkel] #1576859
02/12/14 09:53 PM
02/12/14 09:53 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Yeah they shift like nothing is there after a few clutch dumps and powershifts
Re: 833 tranny fluid [Re: GTX MATT] #1576860
02/12/14 10:36 PM
02/12/14 10:36 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
They have gallon jugs of Sta-Lube 85w-90 GL4 at napa for a really reasonable price. that's what I use and it works great.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: 833 tranny fluid [Re: John_Kunkel] #1576861
02/13/14 01:12 AM
02/13/14 01:12 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Yes, and a toploader and a T5 and a A435 and numerous other manual transmissions, foreign and domestic, even ones you have to double clutch.
Question is, have you ever driven a fresh A833 with a new shifter? When I converted my 87 Diplomat over to stick I rebuilt the trans, rebuilt the clutch linkages, put a Holley pitpack on my new Holley Indy shifter, pulled the Indy apart, polished the lever, cleaned and lubed it and reassembled it. Adjusted the shift and clutch linkages and it was sweet.
Re: 833 tranny fluid [Re: Supercuda] #1576862
02/13/14 04:17 PM
02/13/14 04:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ever wonder why Chrysler developed the "slick shift" modification for the 833?
Re: 833 tranny fluid [Re: DaveRS23] #1576863
02/13/14 04:48 PM
02/13/14 04:48 PM
pa.
dan9 Offline
dan9  Offline
pa.
I bought mine from Passon's last year. He told me to run 80/90w non-synthetic.
Re: 833 tranny fluid [Re: dan9] #1576864
02/13/14 04:53 PM
02/13/14 04:53 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Hmmmm, I put 85W 140 in mine. A buddy told me thats what hes put in his 833s since he bought his '67 GTX brand new. I haven't driven mine yet but you can absolutely rip powershifts with his 833
Re: 833 tranny fluid [Re: John_Kunkel] #1576865
02/13/14 04:55 PM
02/13/14 04:55 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
Agreed....
Even an absolutely PERFECT 833 with all new parts isnt going to be "sweet shifting"..Not in the same way a Muncie or T10 is..Those trannies are as fragile as fine China, though...
The 833 is essentially a truck unit used in car applications...Its VERY strong, but its very heavy, and not meant to be powershifted. And yes, Chrysler knew this very early on, hence the "slick shift" crash boxes..
Use standard 90wt gear oil in most applications...Ive used Sychromesh in race units-but those arent meant for the long haul....I also do NOT recommend synthetic 90 wt...
MB
Re: 833 tranny fluid [Re: GTX MATT] #1576866
02/13/14 05:08 PM
02/13/14 05:08 PM
pa.
dan9 Offline
dan9  Offline
pa.
Since I asked Jamie's advice i will respect his opinion. That gear oil you are using will probably be fine. Since we don't drive them everyday in the winter like we used to. That first shift on a cold morning with a super cold Hurst t-handle was interesting. It got better with the felt covered t-handles.
Re: 833 tranny fluid [Re: GTX MATT] #1576867
02/13/14 05:10 PM
02/13/14 05:10 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
85W-140 is fine, but it's a crutch for a worn box IMO. A worn 833 will not agree with syn or lighter weight fluids. I drove an NP435 quite a bit with Redline MTF. It shifted well, but did find the weak seals for me.
I want my fair share
Page 2 of 3 1 2 3
