Page 2 of 3 1 2 3
Re: What do you guys paint your rollbars with? [Re: Cab_Burge] #1576448
02/09/14 09:55 PM
02/09/14 09:55 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
What's a cage??
Anyone using the VHT roll bar paint? Eventually when I get kicked out a few more times I'll do my cage body color. I think it would look cool with vanilla against black interior.
Re: What do you guys paint your rollbars with? [Re: SpareParts] #1576449
02/09/14 10:26 PM
02/09/14 10:26 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
What's a cage??
I am pretty sure the VHT roll bar paint is the same as their satin black chassis epoxy. Just a different label, I have used them both.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: What do you guys paint your rollbars with? [Re: Challenger 1] #1576450
02/10/14 12:04 AM
02/10/14 12:04 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I wonder if just using a light color would be a decent compromise, since no paint could get out of control for many corrosion wise IMO, and I like the idea of having cracks be obvious.
Re: What do you guys paint your rollbars with? [Re: MR_P_BODY] #1576451
02/10/14 12:50 AM
02/10/14 12:50 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
On the race car I painted it with base coat and a clear
coat but its a complete tube chassis with out the body..
the Rampage I painted with Chassis Saver and a brush
but I'm not real happy with it... I may repaint it with
Rustoleom... the Chassis Saver tends to chip pretty easy
Chassis Saver is supposed to be applied over rusty metal or sandblasted metal. Was your chassis rusty or sandblasted? If it was smooth, it won't stick well at all.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: What do you guys paint your rollbars with? [Re: DusterDave] #1576452
02/10/14 12:57 AM
02/10/14 12:57 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
I knew a guy that had a car with a chrome moly cage with really nice TIG welds. He had Scotchbrited the entire cage, and then sprayed it satin clear. Looked nice, and it showed off those nice TIG welds.
Re: What do you guys paint your rollbars with? [Re: SpareParts] #1576453
02/10/14 01:03 AM
02/10/14 01:03 AM
Az
Crizila Offline
Crizila  Offline
Az
What's a cage??
"Ace" "Appliance Epoxy" black.
Fastest 300
Re: What do you guys paint your rollbars with? [Re: Crizila] #1576454
02/10/14 01:58 AM
02/10/14 01:58 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Valspar satin black.
Re: What do you guys paint your rollbars with? [Re: dartman366] #1576455
02/10/14 02:28 AM
02/10/14 02:28 AM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
Thanks for the responses and good ideas. I want to knock this part out soon so I can get the car painted and put the windshield and back glass back in there. Test fitted the motor and have it sitting in there now...
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576456
02/10/14 10:01 AM
02/10/14 10:01 AM
North Carolina
CALSDART Offline
CALSDART  Offline
North Carolina
I painted mine with RUST-OLEUM Hammered Silver with a brush.
Home Depot
Calvin Thompson
Re: What do you guys paint your rollbars with? [Re: CALSDART] #1576457
02/10/14 12:19 PM
02/10/14 12:19 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Rustoleum Hammer tone black with a small brush, it's actually a metallic gray color. no masking, hard as nails and easy to touch up.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: What do you guys paint your rollbars with? [Re: Adobedude] #1576458
02/10/14 12:32 PM
02/10/14 12:32 PM
Highland beach Fl
P
poisondart2 Offline
poisondart2  Offline
P
Highland beach Fl
VHT epoxy paint
Re: What do you guys paint your rollbars with? [Re: poisondart2] #1576459
02/10/14 01:15 PM
02/10/14 01:15 PM
Alberta, Canada
451Guy Offline
451Guy  Offline
Alberta, Canada
Rustoleum Hammer tone black. Have actually been asked how I was able to powder coat the cage in a back half car? Easy to touch up if required.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank
Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car
Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T
Best ET 11.39 @ 118.11
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576460
02/10/14 02:00 PM
02/10/14 02:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I brushed on "Hammered" paint in a semi-gloss greyish color.
Re: What do you guys paint your rollbars with? [Re: Adobedude] #1576461
02/10/14 02:27 PM
02/10/14 02:27 PM
Renton Washington
Triple Threat Offline
Renton Washington
This is what Mine is as well. I need to repaint the drivers bar, after 2.5 seasons of sliding in and out of the car all the paint is worn off.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: What do you guys paint your rollbars with? [Re: DusterDave] #1576462
02/10/14 03:07 PM
02/10/14 03:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Some of the tubes were rusty... I scotchbrited all
the tubing before applying it to give it some bite..
where I seen it coming off the easiest was on the
trans even after cleaning it good
Re: What do you guys paint your rollbars with? [Re: MR_P_BODY] #1576463
02/11/14 12:16 AM
02/11/14 12:16 AM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
OK so I think what I'm hearing is to get hammered and brush something on there! I'm good with that.
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576464
02/11/14 12:19 AM
02/11/14 12:19 AM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
another...
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576465
02/11/14 01:48 AM
02/11/14 01:48 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Epoxy primer, base coat clear coat. It was easier with the body removed and on a rotisserie.
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576466
02/11/14 01:49 AM
02/11/14 01:49 AM
Roanoke Va
beerwolf Offline
beerwolf  Offline
Roanoke Va
Hey stranger.
Re: What do you guys paint your rollbars with? [Re: beerwolf] #1576467
02/12/14 01:26 AM
02/12/14 01:26 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
POR15 and a foam brush
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Page 2 of 3 1 2 3
