Page 1 of 3 1 2 3
What do you guys paint your rollbars with? #1576428
02/09/14 03:03 PM
02/09/14 03:03 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
I got my car back recently from having the rollcage installed. Just wondering how you guys are painting them and what did you use? I'm guessing the easiest thing would be a spray can deal but lets hear what all you folks did, and pics would be cool too. Thanks!
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576429
02/09/14 03:14 PM
02/09/14 03:14 PM
Toronto
mshred Offline
mshred  Offline
Toronto
Don't have any pics, but I painted mine with a foam brush(es) and gloss black rustoleum in the can. Holding up fine, other then the door bars where it is scuffed from me getting in and out.
Make sure you have REALLY good lighting though if you do it this way...that way you can see if you laid it on too thick or missed any spots.
If I had to do it again, I would have painted all the bars FIRST with a spray bomb, done the welding, and then touch up the areas with a brush (I installed my own cage so this what I found in hindsight would work and look best)
Re: What do you guys paint your rollbars with? [Re: mshred] #1576430
02/09/14 03:20 PM
02/09/14 03:20 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
My car is a 68 Dart,full .083 Chromoly cage with swingout bars. Gearjammer dart is the man and as usual did a great job. Will post some pics later.Just set the engine in for mock up and am hoping to get the cage painted and start working on the outer paint job soon. Wanted to be sure I didn't need to ding or cut or weld anything before the headers got coated or the engine bay painted. It's a tight fit with the 440 in there and I discovered that the wiper motor may not fit with the 8-71 blower. Gonna check that out today.
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576431
02/09/14 03:37 PM
02/09/14 03:37 PM
MR_P_BODY Offline
MR_P_BODY  Offline
On the race car I painted it with base coat and a clear
coat but its a complete tube chassis with out the body..
the Rampage I painted with Chassis Saver and a brush
but I'm not real happy with it... I may repaint it with
Rustoleom... the Chassis Saver tends to chip pretty easy
Re: What do you guys paint your rollbars with? [Re: MR_P_BODY] #1576432
02/09/14 03:40 PM
02/09/14 03:40 PM
tboomer Offline
tboomer  Offline
Re: What do you guys paint your rollbars with? [Re: tboomer] #1576433
02/09/14 04:55 PM
02/09/14 04:55 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I also painted mine with black rustoleum. But it still get scratches on the drivers door bar from getting in and out of the car. So I put tape around that area by the door. I did not want to use foam there as it would hit against the inside door handle and arm rest. Ron
Re: What do you guys paint your rollbars with? [Re: 383man] #1576434
02/09/14 05:07 PM
02/09/14 05:07 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Rustolium rattle can. I removed the armrest so the foam would fit.My door panels are redone with holes for the door lever & windows.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576435
02/09/14 05:13 PM
02/09/14 05:13 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Rustoleum rattle can here too.
Re: What do you guys paint your rollbars with? [Re: dustergirl340] #1576436
02/09/14 05:28 PM
02/09/14 05:28 PM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
Duplicolor rattle can. Holding up well and easy to touch up. I did install the stainless covers on the door bars. Beep
Re: What do you guys paint your rollbars with? [Re: Bigbeep] #1576437
02/09/14 05:51 PM
02/09/14 05:51 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
I had Car Quest mix up automotive paint an put it in spray cans. works good, I fogged a light coat of zinc cromate on the bare metal first.
Re: What do you guys paint your rollbars with? [Re: old_racer] #1576438
02/09/14 06:14 PM
02/09/14 06:14 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I had some single stage mixed up from my paint codes off of the can for EB5 blue mixed in some aerosol cans and sprayed mine. Took forever but looks awesome.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576439
02/09/14 07:19 PM
02/09/14 07:19 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I like the Rustoleum Appliance Epoxy in a rattle can. A little tougher than their regular stuff. I even use it for things under the hood, like air cleaners, brackets, pulleys. Holds up well.
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576440
02/09/14 07:44 PM
02/09/14 07:44 PM
So. IL. USA
PLUM BAD Offline
PLUM BAD  Offline
So. IL. USA
Rustoleum black Hammertone with a sponge brush.
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576441
02/09/14 07:59 PM
02/09/14 07:59 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Nothing, bare metal. Easy to find cracks and easy to weld on which happens all the time plus is lighter (most important) and never has a chip in it and looks so serious, imo.
Scotchbrite pads and WD 40 keeps it rust free.
Easier to see cracks and bends without paint.;)
Re: What do you guys paint your rollbars with? [Re: BEEQUIK] #1576442
02/09/14 08:23 PM
02/09/14 08:23 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Rattle can Rustoleum
Nautilus Racing-
Re: What do you guys paint your rollbars with? [Re: Chris2581] #1576443
02/09/14 08:28 PM
02/09/14 08:28 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Sem trim black or other colors. Check out the website sem products
....BAD A$$ STREET CAR.....
Re: What do you guys paint your rollbars with? [Re: n20mstr] #1576444
02/09/14 08:47 PM
02/09/14 08:47 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Krylon Indoor/Outdoor rattle can if it's not a bare chassis. Spot painting bars in difficult areas, before they go in to stay helps. Easy touch up for wear or modifications.
Re: What do you guys paint your rollbars with? [Re: CMcAllister] #1576445
02/09/14 09:07 PM
02/09/14 09:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Mine is single stage urethane. No clear cote since that would be two times the pain. To do it again the hammertone with the foam brush is the ticket. East, cheap, and looks great.
Doug
Re: What do you guys paint your rollbars with? [Re: n20mstr] #1576446
02/09/14 09:12 PM
02/09/14 09:12 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
+1 I have been using sem for a while now.
started using epoxy paint, lays out nice, no need for primer. fairly durable
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: What do you guys paint your rollbars with? [Re: OUTLAWD] #1576447
02/09/14 09:34 PM
02/09/14 09:34 PM
Rustoleum gloss black with a brush, if it don't look good it must not run good , correct Where are the fishing pole Graemlins when you need it
Page 1 of 3 1 2 3
