Re: What do you guys paint your rollbars with?
[Re: Challenger 1]
#1576450
02/10/14 12:04 AM
02/10/14 12:04 AM
Posts: 22,727 Bitopia
jcc
Bitopia
I wonder if just using a light color would be a decent compromise, since no paint could get out of control for many corrosion wise IMO, and I like the idea of having cracks be obvious.
[Re: DusterDave]
#1576452
02/10/14 12:57 AM
02/10/14 12:57 AM
Posts: 1,845 Tampa
DusterDave
Tampa
I knew a guy that had a car with a chrome moly cage with really nice TIG welds. He had Scotchbrited the entire cage, and then sprayed it satin clear. Looked nice, and it showed off those nice TIG welds.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: BEEQUIK]
#1576456
02/10/14 10:01 AM
02/10/14 10:01 AM
Posts: 90 North Carolina
CALSDART
North Carolina
I painted mine with RUST-OLEUM Hammered Silver with a brush. Home Depot
Calvin Thompson
[Re: CALSDART]
#1576457
02/10/14 12:19 PM
02/10/14 12:19 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Rustoleum Hammer tone black with a small brush, it's actually a metallic gray color. no masking, hard as nails and easy to touch up.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: poisondart2]
#1576459
02/10/14 01:15 PM
02/10/14 01:15 PM
Posts: 474 Alberta, Canada
451Guy
Alberta, Canada
Rustoleum Hammer tone black. Have actually been asked how I was able to powder coat the cage in a back half car? Easy to touch up if required.
Thanx 451 Guy
512 cu in 71 Demon Super Street Car - NO LONGER - Broke Crank Best ET 9.57 @ 139.96
451 cu in Pump Gas - 71 Demon Super Street Car Best ET 9.99 @ 136.80
512 cu in 69 Charger R/T Best ET 11.39 @ 118.11
[Re: DusterDave]
#1576462
02/10/14 03:07 PM
02/10/14 03:07 PM
Posts: 52,972 Romeo MI
MR_P_BODY
On the race car I painted it with base coat and a clear coat but its a complete tube chassis with out the body.. the Rampage I painted with Chassis Saver and a brush but I'm not real happy with it... I may repaint it with Rustoleom... the Chassis Saver tends to chip pretty easy
Chassis Saver is supposed to be applied over rusty metal or sandblasted metal. Was your chassis rusty or sandblasted? If it was smooth, it won't stick well at all.
Some of the tubes were rusty... I scotchbrited all the tubing before applying it to give it some bite.. where I seen it coming off the easiest was on the trans even after cleaning it good
