AN fittings..what brand do you use #1575814
02/08/14 12:48 PM
02/08/14 12:48 PM
PA
bwhackd34 Offline OP
PA
I have always used Earl's or Russell fittings but they are so damn expensive. I am designing and pricing plumbing for my remote mount pump/reverse cooling setup and it is looking like over $700 just for hose/fittings. I was wondering about Fragola or even some of the other brands that I see listed on Ebay. There are even a few Chinese manufacturers selling fittings at fractions of the price of the big name brands but I was concerned about the quality. If I buy the cheapos and have to replace with the better ones anyway it ends up costing money.
Re: AN fittings..what brand do you use [Re: bwhackd34] #1575815
02/08/14 01:05 PM
02/08/14 01:05 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
I've used the Summit brand.
Let's face it, in most cases these fittings are complete overkill - being used where a rubber hose and a ten cent hose clamp would last a lifetime!
In high pressure brake systems or a fuel system I wouldn't skimp on quality but a cooling system only see's about 15 pounds of pressure. I wouldn't hesitate to use a less expensive brand there.
Re: AN fittings..what brand do you use [Re: Stanton] #1575816
02/08/14 01:10 PM
02/08/14 01:10 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I've used all of them ! I know when I was in tech at summit our brand was made by aero ? Don't know if that's still the case or not but I haven't had any issues and they have been on there for some time now. !
Re: AN fittings..what brand do you use [Re: Stanton] #1575817
02/08/14 01:11 PM
02/08/14 01:11 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I use the Jegs house brand pretty much exclusively any more, always used AeroQuip before, never had a failure with eather one.
Re: AN fittings..what brand do you use [Re: 70dusterjohn] #1575818
02/08/14 02:07 PM
02/08/14 02:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I use the Summit brand... any of them cost... these
Summit ones are just a little less pricey... try plumbing
a dry sump.. that will get real pricey even with the
less pricey ones
Re: AN fittings..what brand do you use [Re: dartman366] #1575819
02/08/14 02:14 PM
02/08/14 02:14 PM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
Over on the EBAG, there is a company called Professional Products that sells a 5 pack of fittings, in all sizes and shapes for a really killer price..
So me, being Mr Tightbehind, bought everything I needed for my last motor build and saved a ton of money.. But today, I am slowly replacing the fittings because after a short period of time, the swivel part of the fitting stopped swivelling.. and we all know what a pain it is to remove a fitting only to have the entire hose spins too..
So I saved a dollar to waste a dollar..
Re: AN fittings..what brand do you use [Re: Jeepmon] #1575820
02/08/14 02:20 PM
02/08/14 02:20 PM
Renton Washington
Triple Threat Offline
Renton Washington
If you mix brands of hose and fittings sometimes they dont play well together. My entire fuel system is Earls Pro Lite 350 hose and Earls fittings. The tranny cooler lines are stainless braid from summit with their fittings.
If you dont mind having a summit or jegs logo on them, i've had no issues with their house brands.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: AN fittings..what brand do you use [Re: Triple Threat] #1575821
02/08/14 02:32 PM
02/08/14 02:32 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I've had good luck with the summit brand. Every now and then you get a stubborn swivel, but I've had that with a couple different brands.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: AN fittings..what brand do you use [Re: OUTLAWD] #1575822
02/08/14 03:24 PM
02/08/14 03:24 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
I've used aeroquip, earls, redhorse, summit, Russel....the only ones I didn't like were the red horse one. Hard to put them together correctly. I just buy summit mostly because the are so much cheaper. My brothers shop mostly just uses Summit to because they are good for the price.
Re: AN fittings..what brand do you use [Re: Quicksilver440] #1575823
02/08/14 03:50 PM
02/08/14 03:50 PM
Middletown, Ohio
Joes66dart Offline
Joes66dart  Offline
Middletown, Ohio
I used jegs fittings for most of the car and never had a problem. I did my vaccum pump system with the ebay fittings from proffesional products and the worked great. They sell them in bulk and they end up costing about half of what the jegs fittings cost.
Re: AN fittings..what brand do you use [Re: Joes66dart] #1575824
02/08/14 04:45 PM
02/08/14 04:45 PM
Finland
mafo Offline
mafo  Offline
Finland
I bought some cheap chinese fitting here locally and I can t see any difference compared with the ones that summit or jegs sells?
probably made in the same factory , anyhow they worked great on my transmission cooler
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: AN fittings..what brand do you use [Re: mafo] #1575825
02/08/14 05:46 PM
02/08/14 05:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
Fragola. they look the same as the Aeroquip & KB fittings i used to buy & felt my wallet get raped when i bought them. best part is they're cheaper but the counter guy gives me a discount on this price too.
Re: AN fittings..what brand do you use [Re: bwhackd34] #1575826
02/08/14 07:12 PM
02/08/14 07:12 PM
TN Hoosier
jb500 Offline
jb500  Offline
TN Hoosier
If it's not show quality you are after and just fluid conveyence...then try the industrial hyd hose/fitting route. The money charged for AL fittigns is crazy and waaaaay over priced.
Re: AN fittings..what brand do you use [Re: jb500] #1575827
02/08/14 08:13 PM
02/08/14 08:13 PM
Central Valley, CA.
Central Valley, CA.
That's true...the steel fittings are much cheaper and reusable too.
Re: AN fittings..what brand do you use [Re: bwhackd34] #1575828
02/08/14 09:23 PM
02/08/14 09:23 PM
AndyF Offline
AndyF  Offline
You can use regular water hose and save a lot of money. If the pump has AN threads on it just use adapters. I use regular rubber water lines on the dyno and they work fine. They save a ton of money over the AN hoses and you can quickly cut the rubber lines to length.
Re: AN fittings..what brand do you use [Re: AndyF] #1575829
02/08/14 09:26 PM
02/08/14 09:26 PM
AndyF Offline
AndyF  Offline
The water manifold blocks that I sell can be fitted with hose fittings rather than AN fittings. Then you just cut the rubber lines to size and use a hose clamp. Shouldn't cost more than a few bucks to do all the plumbing this way.
Re: AN fittings..what brand do you use [Re: AndyF] #1575830
02/08/14 09:34 PM
02/08/14 09:34 PM
Oakville, Wa
HOTMOPR Offline
HOTMOPR  Offline
Oakville, Wa
I'd like to see more of your set up with these. Looks cool! I'd like to redo my turbo set up and move it front and center. If that big ol pump was gone it would make life way easier..
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
Re: AN fittings..what brand do you use [Re: HOTMOPR] #1575831
02/09/14 02:10 PM
02/09/14 02:10 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
I buy the cheap 5 packs off ebay. Its nice having extras. Ive never had any problems with them.
Re: AN fittings..what brand do you use [Re: sixpackgut] #1575832
02/09/14 05:42 PM
02/09/14 05:42 PM
Walton's Mountain, Pa
Steve1118 Offline
Steve1118  Offline
"If it's not show quality you are after and just fluid conveyence...then try the industrial hyd hose/fitting route."
So true. One of my sons is a heavy equipment mechanic, and we go to his employer and get those all the time. Most all heavy equipment uses hoses with those ends. Heck, they can probably make you the whole hose for the price of a couple of Earl's fittings.
"Old age and treachery trumps youth and enthusiasm, every time!"
East Central Director / Chrysler Power Magazine
www.reasbeckracing.webs.com
Re: AN fittings..what brand do you use [Re: Steve1118] #1575833
02/09/14 06:36 PM
02/09/14 06:36 PM
brisbane,australia
coletrickle Offline
coletrickle  Offline
brisbane,australia
Ive been using Phenix stuff down here,priced inbetween china and all the big name stuff,USA made,real nice stuff.I belive the owner used to make MRI machines and the like for hospitals sold the company and needdd somethig to keep him active other tham his race car collection and hose fitting he decided was it .
