Re: Need input on dana60 carrier
[Re: Cab_Burge]
#1575684
02/08/14 05:10 PM
02/08/14 05:10 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Cab what are 4.30s listed as?Im planning on them when I do the Dana Gus gave me.Rocky
Chrysler Firepower
[Re: GomangoCuda]
#1575686
02/08/14 09:34 PM
02/08/14 09:34 PM
Posts: 43,230 Bend,OR USA
Cab_Burge
They make both 3 and 4 series 4:30 gear sets.
I went through a lot of searching including calling Strange Engr, Mark Williams, U.S. Gear and several shops the U.S. Gear rep. said to call, it seems like the old Richmond 4.30 Pro gear sets will fit the three sereis carriers and spools, all the regular 4.30 gear sets won't All I can say is good luck on getting it correct the first time I bought a set of U.S. gears from a member on here with a Strange Engr. 35 spline spool that they had used in thier rear end, I run a set of 40 spline Mark Williams axles and it had a set of Pro 5.86 gears on a five sereis Mark Williams aluminum spool. I bought a Moser 4 series 40 spline steel spool and the 4.30 gears wouldn't work on it I bought a used set of Dana OEM 4.56 and put that in the car IHTHs
[Re: DoctorDiff]
#1575690
02/09/14 03:18 AM
02/09/14 03:18 AM
therocks
Niles , Ohio
I intend to contact the good Dr when I start on the rear.Ill need his help with a lot on the Dana.Thanks again for the housing Gus.I have to order some new tires for the Harley first.That will be in March.Then I have to see about someone welding up my 3 inch inboard setup.Rocky
Chrysler Firepower
