Page 1 of 3 1 2 3
Lets see your Low Budget ..... Bracket / Drag Cars... #1575484
02/07/14 03:50 PM
02/07/14 03:50 PM
Creston, Iowa
3
340man4ever Offline OP
Creston, Iowa
Interested in seeing pics.....buildups.....specs....performance of the low budget bracket / and or drag cars on Moparts!
Thanks in advance!
Lets see em
Curator at Adams County Speed Shop
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: 340man4ever] #1575485
02/07/14 04:59 PM
02/07/14 04:59 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
Thanks in advance!
Lets see em
define low budget
I have about 4k in my car but I did everything except for tigging the cage
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: sixpackgut] #1575486
02/07/14 05:13 PM
02/07/14 05:13 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Yes define budget or ET goal. I bought my car turn key for $5500 and it ran 10.60's.
(Of course, that was in 1993.)
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: 340man4ever] #1575487
02/07/14 05:15 PM
02/07/14 05:15 PM
Az
Crizila Offline
Crizila  Offline
Az
Thanks in advance!
Lets see em
Car was given to me in stock form in 94. Base motor and trans was a junk yard E58 360 / 727 from another 79 300.= $325. Probably got 14K in the motor as it sits. Another 600 in the trans and 800 in the diff and suspension - did myself. Cage, fuel system, interior, other mods were some-what off set by selling original interior and I did all work ( Body and paint also = probably another 3K. Odd ball mid 10 second car for about 27K.
Fastest 300
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: Crizila] #1575488
02/07/14 05:18 PM
02/07/14 05:18 PM
Az
Crizila Offline
Crizila  Offline
Az
int.
Fastest 300
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: Crizila] #1575489
02/07/14 05:19 PM
02/07/14 05:19 PM
Az
Crizila Offline
Crizila  Offline
Az
eng.
Fastest 300
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: Crizila] #1575490
02/07/14 05:30 PM
02/07/14 05:30 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
define low budget? Only expensive thing was the 6-pack.
Coming soon!!!!
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: sixpackgut] #1575491
02/07/14 05:30 PM
02/07/14 05:30 PM
Creston, Iowa
3
Creston, Iowa
Thanks in advance!
Lets see em
define low budget
"Low Budget" is a relative term
Everyone will have a different perspective of that
How about around $5,000 or there abouts (give or take)....
Or a build with extraordinary performance per dollar spent.....
That would also be included in my definiton of "Low Budget".....
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: Mr.Yuck] #1575492
02/07/14 05:42 PM
02/07/14 05:42 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
ya, I could pick up 70 Chargers all day long for $500
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: 340man4ever] #1575493
02/07/14 05:57 PM
02/07/14 05:57 PM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
FWIW, here's the combo in my GTX.
1973 "440"
Standard Bore/Standard Stroke
9:1 Compression
906 Heads (Template Porting)
296/557 MP Purple Cam
M1 intake W/750 Silver Claw
3500 Stall JW Converter
Manual Valve Body
8 3/4 rear with 4.56 Gears
3750 Pounds Race weight
12.32 @ 108.5 in Tucson (So Far...)
Nothing fancy...
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: sixpackgut] #1575494
02/07/14 06:19 PM
02/07/14 06:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Well true that part wasn't as cheap as some, but those 67-69 barracudas aren't $500 anymore either.
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: 340man4ever] #1575495
02/07/14 06:55 PM
02/07/14 06:55 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
About 6K in the engine, 418 c.i., 360 block, 4.100 crank, 4.03 bore, production heads-nicely ported, STX-22 Racer Brown flat tappet cam, victor 340 intake. $900 C&S carb, $1700 in 727 trans w/ tranz-act brake and dynamic converter. In 1990 I paid $3500 for running high 11sec. matching #340 Demon, which I raced for a couple years until a piston and rod exited the block at the finish line. I did spend about 2K switching from leaf springs to ladder bars and Koni coil over shocks, $4500 for an alterKtion front suspension and another $500 updating the roll bar to a full cage. Car has had several motors over the years from a $700 318 that ran 11.70s, a couple .04 over stock crank 360s, that one went 10.35, and the other 10.25. Every motor that has been in the car has won way more $$$ than I had in it and I sold the 318 for almost triple what I had in it, and the other 2 360s I still own, One needs a sleeve as it cracked a cyl just under the deck and the other one broke a crank, has been repaired with a new stock stroke 4340 scat crank, which will be in the car for the start of the 2014 season. Best ET has been 9.68 at 136mph. with the engine in the car now, [418 c.i.], has over 1800 passes, and has won as much as 10K in one day and probably close to 100K total including two wheelie contests. A low budget car that has given me a very good return on investment, not to mention the fun it has been along the way.
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: 340man4ever] #1575496
02/07/14 07:01 PM
02/07/14 07:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I built the whole thing myself so for what it is it was
pretty budget... full moly chassis, small block N/A
that runs 8.90s in the 1/4... so for that I'd say its
a real budget build for what I have into it... cant
say that if you add in my time... but this is the stuff
I enjoy doing
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: MR_P_BODY] #1575497
02/07/14 07:15 PM
02/07/14 07:15 PM
Creston, Iowa
3
Creston, Iowa
Great examples guys!
Keep em coming
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: 340man4ever] #1575498
02/07/14 07:19 PM
02/07/14 07:19 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
All garage built. So far way less into it than it looks although now I am on to the expensive part.... The drivetrain is next.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: 6PKRTSE] #1575499
02/07/14 07:24 PM
02/07/14 07:24 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
With a lot of help and used parts this one came in less than 15K.
Doug
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: dvw] #1575500
02/07/14 08:09 PM
02/07/14 08:09 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Doug
If I wasn't there watching the build all along, I would call you a liar... but it's unbelievably true.
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: dizuster] #1575501
02/07/14 08:16 PM
02/07/14 08:16 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Mine is getting more and more out of control (expensive) as I keep leaning on it.
But I traded my labor on 3 transmission rebuilds for the whole car. Core motor was free out of a county truck. Traded an old 300,000 mile beater truck I had for the machine work and port job.
$1000 into the trans converter (built myself)
Traded a trans rebuild to Mr. P and some cash for the roll bar/turbo fab work.
$1000 in parts on the motor
$3000 in turbo parts.
The rest is just junk I stole out of DVW's attic (including the used 3.23 gear, and borrowed posi).
I re did the seats, put carpet in it, new wheels/tires, fuel system etc... I probably could have done it even cheaper if I had left it a little more ratty, but that wasn't what I wanted.
I had ~$8k in it when it ran at the track on the first day. Went 10.99. Later went all the way to 10.08 with more boost, but hurt some parts along the way, so you have to count them in the expense. Probably would go mid/high 10's all day without breaking parts as first built though.
Not $5k, but in the 10's for $8k isn't bad. It would be in the 9's if it were a lighter A-body for the same cost.
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: dvw] #1575502
02/08/14 02:30 AM
02/08/14 02:30 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Doug
Doug no ofense at all meant here as I love that 64 of yours but I dont see how you could have even got the parts for your car under 15k. So I assume you had or traded for alot of the parts. When I look at your beautiful car it makes me think you got 15k in paint work. Cause it is nice. Ron
Re: Lets see your Low Budget ..... Bracket / Drag Cars... [Re: 383man] #1575503
02/08/14 02:42 AM
02/08/14 02:42 AM
BigFish69 Offline
BigFish69  Offline
Buy one get one free Walmart black friday sale.
Page 1 of 3 1 2 3
