Re: bad valve body?
[Re: WV Runner]
#1575237
02/07/14 04:21 PM
02/07/14 04:21 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
More likely the front clutch sealing rings or rubber seals are worn.
If the rubber seals are the problem some "miracle in a bottle" might help. Try Lucas or Trans-X.
Re: bad valve body?
[Re: nytemuvr]
#1575241
02/08/14 04:12 PM
02/08/14 04:12 PM
John_Kunkel
Rio Linda, CA
Going into Neutral at the 2-3 shift is the key, the valve body/linkage is doing its job but the front clutch isn't engaging as it should.
