65 D100 /6 3 speed. If swapping in a BB with the big 262 bell, will this bell mate to the OE 3 speed? The bell has a rectangular bolt pattern except with the lower Pass bolt hole kicked way out sideways from the perfect "rectangle" bolt pattern. Thank you for your time.
