833 Tailshaft questions
#1574916
02/06/14 03:42 PM
02/06/14 03:42 PM
Posts: 1,869 Carmichael, CA
NotEnufGarage
Carmichael, CA
I've got 4 833/833OD that I need to mix and match to get 2 or 3 working units from ;
1) B-Body 833 non OD cast case with bent tailshaft 2) A-Body 833 non OD cast case 3) B/E-body 833 OD aluminum case 4) B/E-body 833 OD aluminum case
What I'd like to end up with are ;
1) A-Body 833 OD aluminum case to put in my 74 Duster behind a mild 360 2) B/E Body 833 or 833 OD for my 70 Challenger behind a mild 440 3) B Body 833 for my 70 Charger Daytona clone project behind a built up 451
Questions -
Can I swap the tailshaft from the A-body 833 and one of the B/E body 833 OD's?
Can I replace the tailshaft from the B-Body 833 with the one from the other 833 OD?
Thanks for any help.
'70 Charger FE5 Daytona Clone 451/727/D60 '70 Challenger FM3 440/833/3.55SG '79 Ramcharger SE 360 '89 Shelby Dakota ‘06 PT Cruiser GT Convertible ‘07 Charger R/T Daytona ‘10 Ram 1500 ST Crew Cab
Yes, I'm a Dodge Boy. Verstehen?
Re: 833 Tailshaft questions
[Re: NotEnufGarage]
#1574919
02/06/14 05:41 PM
02/06/14 05:41 PM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Questions -
Can I swap the tailshaft from the A-body 833 and one of the B/E body 833 OD's? No. The tailshaft and the output shaft have to be paired. The internals of the OD and the standard 833 are not interchangeable.
Can I replace the tailshaft from the B-Body 833 with the one from the other 833 OD? Maybe, though I think that the bearings may be different.
Thanks for any help. Heck yeah.
[Re: NotEnufGarage]
#1574921
02/06/14 07:40 PM
02/06/14 07:40 PM
Posts: 75,050 U.S.S.A.
JohnRR
U.S.S.A.
No , the mainshafts for OD are different where 3rd gear rides is smaller than NON OD .
You'll also note that most A body OD's had 904 sized output shafts, I think I still have an OD A body shaft, but the tailhousing for it went out in my last scrap load last fall .
Can I use a OD shaft in the non-OD housing that I have?
No you can't , the shaft I have has a 904 sized output which is smaller in diameter than the non od 833 A body output which is 727 ... unless the first year of the slip yoke A body 833 is 904 sized and you would have to have that trans to begin with.
[Re: Cab_Burge]
#1574922
02/06/14 07:45 PM
02/06/14 07:45 PM
JohnRR
U.S.S.A.
Questions -
I would take the bent one out and remove the bearing that rides in the case, measure the the diameter of the shaft where the bearing rides on and then take the other tranny apart that you want to swap parts with and remove and measure the output shaft where that bearing rides on, if they are the same install the parts you want to use on that shaft and assemble it If there not the same diameter see if there is a bearing that has the proper I.D. and O.D for the case and shaft that you want to use, if so get one and go for it If not make another plan like having the bent output shaft straightened
Cab, it's not the bearing, 307 and 308 bearing have the same ID where it goes on the shaft. It's the end of the shaft where 3rd gear rides, it is physically smaller than a non OD trans.
