need advice on flat tappet cam for roadracing HEMI #1573688
02/03/14 07:52 PM
02/03/14 07:52 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
we found out that the STX21 cam that came with the used HEMI that I bought is worn beyond specs, so a set of new camshaft with lifters is on the line.
I'm looking for a cam in the 300° adv.duration and .550 lift at the valve range.
Which cam would you recommend ?
The lifter bores are .907. Should I stick with standard .903 lifters ? Which solid flat tappet lifters would you recommend ?
Re: need advice on flat tappet cam for roadracing HEMI [Re: docford] #1573689
02/03/14 08:11 PM
02/03/14 08:11 PM
AndyF Offline
AndyF  Offline
Chase Knight from Crane is a member on here so I'm sure he could give you some suggestions.
Mike Jones would be another cam grinder to chat with. He probably has a handle on road racing Hemi engines.
Re: need advice on flat tappet cam for roadracing HEMI [Re: docford] #1573690
02/03/14 08:15 PM
02/03/14 08:15 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
What do you mean by " worn beyond specs "
What lifters would you use other than what is available? I don't know of any oversize lifters and Chrysler stopped having those available a LONG time ago .
Re: need advice on flat tappet cam for roadracing HEMI [Re: docford] #1573691
02/03/14 08:27 PM
02/03/14 08:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With the lifter bores worn that much I would have
them bushed
Re: need advice on flat tappet cam for roadracing HEMI [Re: docford] #1573692
02/03/14 08:52 PM
02/03/14 08:52 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Call Jim at Racer Brown and get a new STX-21 or have him regrind your old one. If the lifter bores are .907 you should have them bushed.
Racer Brown phone #410-866-7660
Re: need advice on flat tappet cam for roadracing HEMI [Re: MR_P_BODY] #1573693
02/04/14 05:48 PM
02/04/14 05:48 PM
JohnRR Offline
JohnRR  Offline
them bushed
, buy your lifters and have the bushings sized for the proper clearance, plus enjoy a little power increase from having the correct lifter to cam geometry .
Re: need advice on flat tappet cam for roadracing HEMI [Re: docford] #1573694
02/04/14 05:58 PM
02/04/14 05:58 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Why not just step up to a roller?
Re: need advice on flat tappet cam for roadracing HEMI [Re: JohnRR] #1573695
02/04/14 06:43 PM
02/04/14 06:43 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
the exhaust lobe of the #8 cylinder has 0.060" less lift than the others and all lobes are fully shiny accross their whole surface.
Lifter bores measure at .907 and lifters are .902, so standard .903 lifters or COMP CAMS .904 lifters should work
Re: need advice on flat tappet cam for roadracing HEMI [Re: jcc] #1573696
02/04/14 06:45 PM
02/04/14 06:45 PM
Munich, Bavaria
docford Offline OP
docford  Offline OP
Munich, Bavaria
because I'd like to rebuild it like it was back in the day
