The two fluids are NOT compatible and will not mix.
Take a small glass jar and put a small amount of the two fluids in it. Let is sit. Then shake it vigorously. lets it settle again. Any questions ????
I would suggest you disconnect the lines and hoses
blow through them with low pressure air ( ie: 5 -10 PSI).
Flush them several times with brake clean followed with low pressure air.
Rebuild and or Replace the cylinders and calipers.
Also be aware that the bleeding process needs to be done slowly as the DOT 5 is prone to aerating if pushed through to fast
![](/ubbthreads/images/graemlins/Twocents.gif)
