1970 Challenger Shaker set up
#1573522
02/03/14 10:33 AM
02/03/14 10:33 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. Trying to help a friend locating ( if there is anyone out there ), who reproduces everything needed to install a Shaker setup ( 6bbl ) on a '70 Challenger. I see AMD reproduces the hood?
Cheers, Troy
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: 1970 Challenger Shaker set up
[Re: hemi68charger]
#1573524
02/03/14 12:44 PM
02/03/14 12:44 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
I got two complete hemi hoods w/ shaker kit from Art at sixpackperformance.com & think he uses Gene Gregory's stuff. They turned out great & I was really pleased with the quality. I think I read on a thread here that Gene is not reproducing his shaker stuff anymore, but don't know if this is true. I'm sure someone who knows will chime in. Art is in New Mexico. Here's his website link www.sixpackperformance.net
[Re: Triggerfish]
#1573525
02/03/14 12:59 PM
02/03/14 12:59 PM
hemi68charger
Houston, Tx
Thanks guys.. I forgot about shakerhood.com.....
Cheers,,,, I will pass on the info to my friend.........
Troy
[Re: hemi68charger]
#1573526
02/03/14 10:31 PM
02/03/14 10:31 PM
Posts: 4,785 Ontario, Canada
mccannix
Ontario, Canada
Click on the link and you'll get some answers from that older thread. You have to mix and match these days to get a good looking assembly to sit on the engine. Quite sure Art uses mostly Gene Gregory's stuff with the exception of the grills as Snobar is the only game in town these days for those. Same with the 4 barrel bases and round lid, Snobar is the only one to offer those. Hemi and 6 pak lids from either vendor are of equal quality, but I'm not even sure if Gene offers lids any more. The Hemi and 6 pak bases from both are about the same quality, both having real thick bridges which doesn't really mean a thing. Genes studs seem to pop out of his bases occasionally, poorer projection weld than factory offerings,... Ben tacks his unlike factory so less chance of that happening. Gene makes a better scoop in my opinion but I heard his supplier recently stopped and Gene had to turn else where. I have always heard AAR makes a pretty accurate scoop these days but have never seen them. I like Genes adapter better because it has the more correct definition but Ben has a more accurate looking bellcrank and swivel. Gene's bellcrank can someimes be seen spotwelded back too far on the adapter, and both adapters have several inconsistencies verses real ones but they will not affect function. Hot/cold doors are about the same from each but if piecing a unit together, I would buy Dale Tuels doors and cables as you cant beat the price. I did like the late Fritz cables though. Dale offers a seal with glue that has to be glued together...for a few bucks more Snobars is much the same but already joined. That is just one persons' opinion dealing with this stuff in the past, although I am no expert on the matter.
