E-body Dash Frame Screws? #1573423
02/03/14 01:55 AM
02/03/14 01:55 AM
California, USA
filmsurgeon Offline OP
California, USA
Getting ready to paint my E-body dash frame. As I took off each piece, I put the screws back in the exact same location. For the most part they are all #8 x 1/2" (for the trim, light bar, etc), but have two different head-types. Some are "Phillips Pan-Head Tapping Screws", and some are "Phillips Washer-Head Tapping Screws". Were both these types of screws used originally, or was only one type used? If both types, then would someone be able to tell/show me which type gets used where? I will be removing (before painting) and replacing all the U-nuts with new correct size black phosphate U-nuts. Thanks.
Re: E-body Dash Frame Screws? [Re: filmsurgeon] #1573424
02/03/14 03:48 PM
02/03/14 03:48 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
the one on the left
Re: E-body Dash Frame Screws? [Re: filmsurgeon] #1573425
02/08/14 08:29 PM
02/08/14 08:29 PM
Rio Linda, CA
N
nytemuvr Offline
nytemuvr  Offline
N
Rio Linda, CA
Easiest way to put it, if it shows it's flat(not many) and if not seen(light bar, gauges)it's rounded....original owner here.
1972 Challenger 340(original owner) 1968 D100 1997 HD Road King
