Six Pack Intake Question #1573417
02/02/14 11:53 PM
02/02/14 11:53 PM
Iowa
Davtona Offline OP
Davtona  Offline OP
Iowa
Hey new to the six pack world here. What is the difference between the 2946275 and the 2946276 440 six pack intake numbers. Is one a part number and the other a casting number as I suspect. Also on a 1970 V code Charger with a November 21 build date what date code of intake should I be looking for. Thanks in advance.
Re: Six Pack Intake Question [Re: Davtona] #1573418
02/03/14 12:22 AM
02/03/14 12:22 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Cast Iron for 70, both numbers you have are casting numbers for the 2 cast iron manifolds offered during 1970...2946275 is an early casting for 1970, casting #2946276 was used later in 1970 production, 276 was a retool, as the early iron manifolds (275) had casting issues
