Gast Tank straps? Black or silver..? #1573005
02/02/14 04:12 PM
02/02/14 04:12 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
70 RR. Which is correct? Have seen both...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Gast Tank straps? Black or silver..? [Re: JMCFAN] #1573006
02/02/14 04:29 PM
02/02/14 04:29 PM
okla.
O
okie Offline
okie  Offline
O
okla.
All I've seen have been silver
Re: Gast Tank straps? Black or silver..? [Re: okie] #1573007
02/02/14 05:00 PM
02/02/14 05:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Originals were raw metal (as in "unpainted"), however, a full undercoat optioned car would have had them covered in undercoating along with most of the tank.
Re: Gast Tank straps? Black or silver..? [Re: JMCFAN] #1573008
02/02/14 05:07 PM
02/02/14 05:07 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Galvanized silver is what I have seen on originals
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: Gast Tank straps? Black or silver..? [Re: ScottSmith_Harms] #1573009
02/02/14 07:11 PM
02/02/14 07:11 PM
Scott,
Our factory full undercoated 69 GTX had only the sides of the gas tank undercoated and not the bottom of it. Probably varied from plant to plant and worker to worker.
Re: Gast Tank straps? Black or silver..? [Re: ] #1573010
02/02/14 07:15 PM
02/02/14 07:15 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Scott,
Yes, I agree, coverage absolutely varied. My point for mentioning it was to point out that the straps were not always clean and shiny when new
Re: Gast Tank straps? Black or silver..? [Re: ] #1573011
02/02/14 07:56 PM
02/02/14 07:56 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
Scott,
My 500 convertible was the same way, mostly on the sides and front by the fuel sending unit, just a few spatters on the bottom from overspray
