Re: Camber-tire wear-street setting? [Re: PasiR] #1572815
02/04/14 10:48 AM
02/04/14 10:48 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
What brand gauge you guys use for adjustment, how about price of them?
Or is it better to visit at alignment shop?
I use this. I also when to a buddy's shop on put the car on his alignment machine and it was very close. Took him about 15 minutes to get it to what I wanted. Biggest issue is having a level surface to work off of.
http://www.longacreracing.com/catalog/item.asp?id=129&catid=5
With this adapter to bolt directly to the spindle during mock up
http://www.longacreracing.com/catalog/item.asp?id=138&catid=5
Re: Camber-tire wear-street setting? [Re: brads70] #1572816
02/04/14 10:42 PM
02/04/14 10:42 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Firestone has a one time fee for a lifetime alignment..... Make friends with the guy and you can see the adjustments in real time and it makes doing bump, camber, etc real easy!
I change mine at least 5 times a year, no charge.
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
Re: Camber-tire wear-street setting? [Re: Viol8r] #1572817
02/05/14 04:16 AM
02/05/14 04:16 AM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I tried that with the local Firestone dealer because I know they have new hi-tech equipment (and they've done a good job on the family vehicles)... but when asked to do the alignment on my Chally, to my specs... no go.. because they supposedly have to follow OE specs.. since they are a national "franchise".. good luck.. maybe your local franchise dealers work differently under different policies (so instead, I went to a local private shop and actually helped him do the re-alignment to MY specs... and the pizza dinner at night after the shop closed was well worth it and fun, too!.
Re: Camber-tire wear-street setting? [Re: Mopar Mitch] #1572818
02/05/14 04:45 AM
02/05/14 04:45 AM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I get to be involved! No OE specs here! Like I said, it had to be a friend.
