How Do You Press On An Alternator Pulley? #1572666
02/02/14 02:23 AM
02/02/14 02:23 AM
Spokane Valley, WA
Big Bad Bee Offline OP
Spokane Valley, WA
I used a standard pulley puller to get it off, but how do I get the pulley back on my alternator? The local parts houses are absolutely no help on old mopar stuff. Since the old pulley shafts aren't tapped and drilled, the kits they sell don't work. I don't want to put pressure on the front bearing by using a steering wheel puller. All I can think of doing is pulling the alternator apart and pressing the pulley back on with a hydraulic press.
what's the method?
I’m listening.
Re: How Do You Press On An Alternator Pulley? [Re: Big Bad Bee] #1572667
02/02/14 02:35 AM
02/02/14 02:35 AM
split the case so you can support the back side. Freeze the alt half overnight in the freezer & slightly heat the pulley to expand the ID. Hyd press.
Re: How Do You Press On An Alternator Pulley? [Re: RapidRobert] #1572668
02/02/14 02:53 AM
02/02/14 02:53 AM
Spokane Valley, WA
Spokane Valley, WA
Gotcha. Freezing the shaft won't be difficult around here. A night in a ziplock bag out in the snow should do it!
I’m listening.
Re: How Do You Press On An Alternator Pulley? [Re: Big Bad Bee] #1572669
02/02/14 12:44 PM
02/02/14 12:44 PM
Makes me think of our member "Casey" the bear who just moved from the sun & the beaches & the babes of Hawaii over to your neighborhood. I told him that it rains (& snows) in the Northwest US of A (washington/Oregon) 360 days a year & he didn't listen
Re: How Do You Press On An Alternator Pulley? [Re: Big Bad Bee] #1572670
02/02/14 09:42 PM
02/02/14 09:42 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
You don't have to disassemble the alternator to get the pulley back on.
What I do is place the pulley directly on a 100 watt light bulb. Leave it on for five minuets or so.
This will get it hot enough to expand so with a pair of thick gloves you can slide it into position.
I like to have the alternator on the car so I can check for proper belt alinement. Doing it like this is a bit of a pain, but you know its right.
Re: How Do You Press On An Alternator Pulley? [Re: convx4] #1572671
02/03/14 01:10 AM
02/03/14 01:10 AM
Trick
Re: How Do You Press On An Alternator Pulley? [Re: RapidRobert] #1572672
02/03/14 10:42 AM
02/03/14 10:42 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
That is serious overkill.
Don't be the exception.
Re: How Do You Press On An Alternator Pulley? [Re: Supercuda] #1572673
02/03/14 12:31 PM
02/03/14 12:31 PM
After reading the 100 watt light bulb trick I would have to agree. So much for K.i.s.s.
Re: How Do You Press On An Alternator Pulley? [Re: RapidRobert] #1572674
02/03/14 01:15 PM
02/03/14 01:15 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Heat the pulley for a couple of minutes with a torch and drop it over the shaft. *no brainer*
Re: How Do You Press On An Alternator Pulley? [Re: convx4] #1572675
02/03/14 02:22 PM
02/03/14 02:22 PM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Makes me want to go out and try it. only thing I'd have to remove a pulley first
Re: How Do You Press On An Alternator Pulley? [Re: Mr340] #1572676
02/03/14 02:33 PM
02/03/14 02:33 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
wher you gunna find a 100 w bulb? do these new bulbs get that hot?
Re: How Do You Press On An Alternator Pulley? [Re: Mr340] #1572677
02/03/14 02:37 PM
02/03/14 02:37 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Do it the right way,split the case,support rotor,press it on and be done with it,if you don't have a press get someone else to do it,don't make easy things complicated .
Re: How Do You Press On An Alternator Pulley? [Re: bonefish] #1572678
02/03/14 03:22 PM
02/03/14 03:22 PM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
1500 watt heat gun will do the trick.
"I think its got a hemi"
Re: How Do You Press On An Alternator Pulley? [Re: 62maxwgn] #1572679
02/03/14 03:41 PM
02/03/14 03:41 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Thank-You...
Re: How Do You Press On An Alternator Pulley? [Re: RSNOMO] #1572680
02/03/14 03:50 PM
02/03/14 03:50 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
If it slides on by heating the pulley then why is tearing it apart & pressing so much better? Could certainly understand if heating doesn't do the trick...
Re: How Do You Press On An Alternator Pulley? [Re: MO_PA] #1572681
02/03/14 04:47 PM
02/03/14 04:47 PM
Lakeland FL
floridian Offline
floridian  Offline
Lakeland FL
I believe that is what a "Rosebud" torch head is for
Re: How Do You Press On An Alternator Pulley? [Re: floridian] #1572682
02/03/14 05:24 PM
02/03/14 05:24 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And how do you know when it's seated properly ?
Re: How Do You Press On An Alternator Pulley? [Re: 62maxwgn] #1572683
02/03/14 08:14 PM
02/03/14 08:14 PM
BDW Online content
BDW  Online Content
I'd have to do some calculations, but just off the top of my head, I think I be worried about steel that would expand from the heat of a 100W light bulb?
Here we go:
Ok, thermal expansion of steel .0000076in/deg
100w bulb temp 470 deg
so: change in temp is 400, 400 x .0000076 = .00304 thermal expansion,
if pulley diameter is 1/2", then .00304 x 1/2" = 0.0015"
or 1.5 thousands, maybe that is enough?
Re: How Do You Press On An Alternator Pulley? [Re: BDW] #1572684
02/03/14 09:31 PM
02/03/14 09:31 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Here we go:
Enough pressure is required to seat the pulley on the inner race of the drive end bearing,if you just heat to install,how would you know it was there ?
Re: How Do You Press On An Alternator Pulley? [Re: 62maxwgn] #1572685
02/04/14 12:22 AM
02/04/14 12:22 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i just push them on as far as they will go then you can pull it out a little at a time till its lined up.i do it on the car or run stand.
