You might want to make sure its the pan leaking and not something above it. IE: the fluid will sometimes drain down to the lip of the gasket and disperse along the lip to a low point and then drip. This can lead one to think it's the pan or gasket due to it being wet.
Common areas on a TF that will sometimes cause this
The low reverse band strut seal (don't overlook this one it's notorious for selling pan gaskets)
Dipstick tube
Trans lines and fittings
Shift selector seal
kickdown seal
neutral safety / backup light switch.
I normally clean everything thoroughly with brake clean and wait and watch.
I have heard of sprinkling baby powder around the areas as it will turn pink when it sees the fluid. never tried it but thought I would mention it Keep us posted
