Re: Aluminum heads going soft???
[Re: mopartruckguy]
#1571639
01/31/14 05:44 PM
01/31/14 05:44 PM
Challenger 1
Cincinnati, Ohio
I have ran many different aluminum heads, many. I ran aluminum chevy heads in the early 90s and no trouble ever. My 1985 3 wheel ATV has a aluminum head also and it still runs great. First time I have ever heard of that. I have run aluminum heads on BBC, SBC, BBM, and SBM and Brad hemi heads and others I'm sure. I have had a set of eddies on my 340 since 2007 and have driven the car almost 20K miles so far in some really hot and cold conditions. Like Vegas in July and Reno in Aug and pikes peak at 32 degrees. Plus ran the car wide open at Bonneville for miles at a time. I put my 340 eddie heads though extremes and they have held up great. Can't believe what people say, just like the internet. We are all full of sh!t. The only way to find out for sure is to get off the internet and just go do it yourself and become experienced. Good thing my Brad heads didn't go "soft"!
[Re: Cab_Burge]
#1571647
02/01/14 01:50 AM
02/01/14 01:50 AM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
Well... One thing I can think of is that I have seen old coolant turn acidic and eat through aluminum intakes. Not so much a matter of the metal "going soft" as much as the metal getting eaten away because someone was too cheap or lazy to change the antifreeze once or twice a decade.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Michael Ecks]
#1571648
02/01/14 02:00 AM
02/01/14 02:00 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Maybe your buddy sniffed too many Nitro fumes! Aluminum doesn't go soft. It does corrode if the proper coolant isn't used. Electrolysis occurs when straight water is used and left in the engine. After awhile, corrosion forms and can make the aluminum weaker and porous.
[Re: TJP]
#1571649
02/02/14 12:04 AM
02/02/14 12:04 AM
Posts: 1,090 Saskatchewan, Canada
barracudabob
hey may have been old heads and needed a bit of Viagra or Cialis in the oil. I heard that will stiffen them right back UP
Yea, but only for four hours!
[Re: Menzaero]
#1571651
02/02/14 12:42 AM
02/02/14 12:42 AM
Challenger 1
Cincinnati, Ohio
I have seen aluminum plate and bar that doesn't meet mechanical properties from the producing mill due to problems with the thermal ageing process. Perhaps the heads never met properties and somehow escaped the quality control checks and the billet was shipped to the machining house where the heads were machined and assembled.
I'm sure the OP friend had cast aluminum heads, not billet.
[Re: Challenger 1]
#1571652
02/03/14 09:33 PM
02/03/14 09:33 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
I heard that Saturn 1 cam engines develop porosity in the aluminum block beyond 100k miles. Twin cam version does not have the same issue. Porosity is not the same as "soft" in my mind, but maybe that's what he was suggesting. Or straight bluffing.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
