383 HP Quality Engine Rebuild Kits For Budget Build #1571301
01/30/14 06:27 PM
01/30/14 06:27 PM
Washington State
70_FY1_N96_BEEP Offline OP
Washington State
I'll be handing my motor off to the builder in March. Will be doing a standard rebuild but want best of components. My question is does anyone put a quality complete kit together less the camshaft, lifters, and springs? Or can someone direct me to someone who kits these type of things? This is a stock rebuild, but I'd like forged pistons, Melling pump and chain. Thanks a TON Moparts!!
Re: 383 HP Quality Engine Rebuild Kits For Budget Build [Re: 70_FY1_N96_BEEP] #1571302
01/30/14 06:41 PM
01/30/14 06:41 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Re: 383 HP Quality Engine Rebuild Kits For Budget Build [Re: Dean_Kuzluzski] #1571303
01/30/14 06:48 PM
01/30/14 06:48 PM
an8sec70cuda Offline
http://chucker54.stores.yahoo.net/micenkitd1.html
I'd be interested to see what kind of compression those pistons will give you. Not easy to find 383 pistons that have a decent compression ratio.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: 383 HP Quality Engine Rebuild Kits For Budget Build [Re: 70_FY1_N96_BEEP] #1571304
01/30/14 07:55 PM
01/30/14 07:55 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
When I restored my 383 in my Road Runner years ago,I got a whole kit from Speed-O-Motive.I wanted to only go +.020 max on overbore and thay got all what I needed at a very good price.
Nautilus Racing-
Re: 383 HP Quality Engine Rebuild Kits For Budget Build [Re: Chris2581] #1571305
01/31/14 03:14 PM
01/31/14 03:14 PM
dogdays Offline
dogdays  Offline
Do a Google search for SpeedOMotive and read up. Then you'll go somewhere else.
I don't see the value of a "kit" as most of the 383 pistons on the market will get you compression in the very low 8s.
JohnRR is the man when it comes to knowing the choices for 383s.
R.
Re: 383 HP Quality Engine Rebuild Kits For Budget Build [Re: dogdays] #1571306
01/31/14 03:31 PM
01/31/14 03:31 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
1969 Dart GTS 340
1969 Coronet R/T X9 N-96
1999 Dodge Dakota R/T RC
2015 Dodge Dart GT
2019 Ram 2500 Big Horn
Re: 383 HP Quality Engine Rebuild Kits For Budget Build [Re: 70_FY1_N96_BEEP] #1571307
01/31/14 06:04 PM
01/31/14 06:04 PM
Delray beach, Florida
P
Performance Only Offline
P
Your engine builder should be able to get you everything you need. If not, we do a lot of engine kits to varying degrees. Are you looking for crank, rods, pistons, rings, bearings, gaskets, etc., or just some of those things?
There is no forged off the shelf 383 piston that has the compression height to give you decent compression and quench. We just change the C/H on a shelf piston from Diamond to get what we need after the block has been machined.
machine shop owner and engine builder
Re: 383 HP Quality Engine Rebuild Kits For Budget Build [Re: Performance Only] #1571308
01/31/14 06:30 PM
01/31/14 06:30 PM
Washington State
Washington State
That is exactly what AndyF just told me. Diamond's with the pin bore moved. And that's AFTER block work is done. I like it! Thanks everyone for the help. My builder has 2 National Championships under his belt so I'm comfortable now.
Re: 383 HP Quality Engine Rebuild Kits For Budget Build [Re: Performance Only] #1571309
01/31/14 08:58 PM
01/31/14 08:58 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Or get the Speed Pro 2315 pistons and 915 heads.
Re: 383 HP Quality Engine Rebuild Kits For Budget Build [Re: Performance Only] #1571310
02/01/14 01:48 PM
02/01/14 01:48 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Dan beat me to it , I was going to tell you to contact this guy and he will set you up with exactly what you need.
As an FYI , if you want a REAL 10.0 compression 383 it requires a zero deck piston and a head with 80cc combustion chamber . I would do as someone above mentioned and build it with 915's if you want stock look or a closed chamber Alum head .
Have the block squared THEN get your piston made .
