1971 Seat Belt Button Style #1570875
01/29/14 10:00 PM
01/29/14 10:00 PM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
My question is about the two different seat belt button styles I have seen on some original belts.
Which seat belt button is correct for a late build 71 dodge challenger?
Re: 1971 Seat Belt Button Style [Re: JAK] #1570876
01/29/14 10:01 PM
01/29/14 10:01 PM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
second seat belt button
Re: 1971 Seat Belt Button Style [Re: JAK] #1570877
01/29/14 10:47 PM
01/29/14 10:47 PM
Calgary, Alberta Canada
m46rat Offline
m46rat  Offline
Generally speaking the solid silver ones were used on all early built 71 belts up to about early December, after that both types were used and you can find both types even in the same vehicle, up to the end of 1971 production.
Re: 1971 Seat Belt Button Style [Re: m46rat] #1570878
01/30/14 08:14 PM
01/30/14 08:14 PM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
Re: 1971 Seat Belt Button Style [Re: JAK] #1570879
01/31/14 01:40 PM
01/31/14 01:40 PM
m46rat Offline
m46rat  Offline
If you need any, I have several originals in great shape, depending on what color the belts are that you need.
Re: 1971 Seat Belt Button Style [Re: m46rat] #1570880
01/31/14 07:52 PM
01/31/14 07:52 PM
Washington
69440 Offline
69440  Offline
Washington
I also have dozens of them, if you need any, 69440
Re: 1971 Seat Belt Button Style [Re: 69440] #1570881
01/31/14 09:41 PM
01/31/14 09:41 PM
Waterford, MI
JAK Offline OP
JAK  Offline OP
Waterford, MI
I will keep you guys in mind if I need some belts. I need to go through the belts I have to see what I might need.
