Re: any trick to removing Ball Joints from UCA's?
[Re: stumpy]
#1570752
01/31/14 01:18 AM
01/31/14 01:18 AM
Posts: 654 MN
astrobuf
MN
Leave the control arms on the car to remove the ball joints or you could end up twisting them out of shape.
Exactly. You need the socket. While you might use a pipe wrench to take the old Ball joint out, you gotta have the socket to put the new one in! Put the arm back in the car BTW before you screw the new ball joint back in.
Astrobuf ![](/ubbthreads/images/graemlins/iagree.gif)
[Re: astrobuf]
#1570753
01/31/14 04:21 AM
01/31/14 04:21 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
The force required to use a breaker bar on the UCA ball joints was going to pull my car off the jack stands. Finally got them off with an impact wrench, but just barely - really needed a bigger, heavier duty impact wrench than my Sears.
[Re: kentj340]
#1570754
01/31/14 11:33 AM
01/31/14 11:33 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
3' pipe over breaker bar and still I thought the car was going to come off the lift. All the while, I kept thinking to myself when it refused to budge, I must be doing this wrong.... ![](/ubbthreads/images/graemlins/rant.gif)
[Re: Commando1]
#1570755
01/31/14 12:53 PM
01/31/14 12:53 PM
Posts: 5,911 Athens, Greece
Pyper70
Athens, Greece
I doubt my 1/2 Snap On Impact with 150lbs behind it is going to crack them loose...I might have to resort to putting on my 3/4" Sears breaker bar w/ 1/2 adapter and an additional 3' stainless pipe I have for occasions like this.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: justinp61]
#1570760
02/09/14 10:48 PM
02/09/14 10:48 PM
Posts: 1,376 NORTHERN CA
HUSTLESTUFF
NORTHERN CA
If I'm not reusing I weld a 1" nut to them and use impact to remove them
"Were in it to win it. Anything less will end up being..... A whole lot of fun doing!!" UNLAWFL RIP UN
[Re: HUSTLESTUFF]
#1570761
02/10/14 02:22 AM
02/10/14 02:22 AM
Posts: 1,145 ontario calif
ns1aar
ontario calif
Air chisel be careful to not nick the arm though
NS1AAR
