is the 3-4 rod journal most oil starved on a hemi?
#1570379
01/28/14 09:57 PM
01/28/14 09:57 PM
Posts: 7,528 Minnesota
Hemi_Joel
Minnesota
is the 3-4 rod journal most Likely to suffer from oil starvation and burn the bearings on a hemi? If so, why and what is the cure?
Thanks, joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: is the 3-4 rod journal most oil starved on a hemi?
[Re: Hemi_Joel]
#1570381
01/29/14 12:03 AM
01/29/14 12:03 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thanks, joel
Normally its the 5-6 being the last inline but thats the way it is on all of the BB and even SB
[Re: Mopar_Rich]
#1570382
01/29/14 12:37 AM
01/29/14 12:37 AM
Hemi_Joel
Minnesota
No. Why would you think so? The HEMI is the same as any RB.
\ I bought a Hemi years ago in "unknown" condition. when I tore It down the number 3 rod bearing was toast. Then I blew up another one in 2010 when I accidentally over-revved it. Rod Number 3 went thru the side of the block and when I looked at the #3 crank journal it was all black. So I'm just wondering if it is a Pattern
[Re: Hemi_Joel]
#1570383
01/29/14 12:43 AM
01/29/14 12:43 AM
MR_P_BODY
It was either tight or had some trash blocking the port... actually the number 7 is the weak one if I remember right
[Re: Hemi_Joel]
#1570385
01/29/14 01:11 AM
01/29/14 01:11 AM
Posts: 1,938 Sonora CA
Mopar_Rich
Sonora CA
Just bad luck or poor assembly techniques.
