BB Mopar Crank Drive Mandrels #1570235
01/28/14 04:30 PM
01/28/14 04:30 PM
Out West
408strokerdart Offline OP
Out West
What is everyone using for a Vac pump or oil pump drive mandrel when using a BB Mopar balancer with a Chevy bolt pattern? Nothing clears the head of the damper bolt.....it's not even close with an ARP damper bolt. Who makes mandrel drives?
I've already checked Peterson, Moroso, Star....
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570236
01/28/14 04:33 PM
01/28/14 04:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm not home with my books but CV Products is where
I got all my drive stuff from
Re: BB Mopar Crank Drive Mandrels [Re: MR_P_BODY] #1570237
01/28/14 04:46 PM
01/28/14 04:46 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Just throwing this out there Brian but did you try Rons?
http://www.ronsfuel.com/carb_access.cfm
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.38@138.67
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570238
01/28/14 05:19 PM
01/28/14 05:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Brian... this is one way for the CV system... they
have a bolt on plate to the balancer and then you add
what you want... or as in my case I used the bolt on
pulley then added what I wanted then the "HAT" at
the end with the center bolt
Re: BB Mopar Crank Drive Mandrels [Re: pittsburghracer] #1570239
01/28/14 05:28 PM
01/28/14 05:28 PM
Out West
Out West
Haven't looked there yet. Thanks.
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570240
01/28/14 05:30 PM
01/28/14 05:30 PM
AndyF Offline
AndyF  Offline
I used the Peterson spline drive setup and then clearanced the back side for the bolt head.
Re: BB Mopar Crank Drive Mandrels [Re: MR_P_BODY] #1570241
01/28/14 05:31 PM
01/28/14 05:31 PM
Out West
Out West
I haven't looked at CV yet either. The big problem is with the BB balancer hub because it forces the balancer bolt to sit proud of the balancer a good distance where a SB Mopar balancer hub allows the balancer bolt head to sit below the front face of the balancer. Whatever bolts to the balancer face needs to have a large counterbore to clear the bolt head. Nothing I can find yet has this.
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570242
01/28/14 06:19 PM
01/28/14 06:19 PM
south central pa
bdaz smblk Offline
bdaz smblk  Offline
south central pa
I have a aerospace on mine.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570243
01/28/14 06:20 PM
01/28/14 06:20 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I use a GZ with mine.I run a flat faced Fluid Damper. It all fit perfect. However the ones they show are different than mine
Doug
http://www.gzmotorsports.com/
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570244
01/28/14 10:45 PM
01/28/14 10:45 PM
louisiana
hemi-hunter Offline
hemi-hunter  Offline
louisiana
BO LAWS
Re: BB Mopar Crank Drive Mandrels [Re: AndyF] #1570245
01/28/14 10:57 PM
01/28/14 10:57 PM
Out West
Out West
There was enough meat there to cut some away? How deep did you have to counterbore? You just used a standard hex head screw right....not the ARP?
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570246
01/28/14 11:15 PM
01/28/14 11:15 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Might look here. Always had good luck with Jones Products for pullies and belts. I have also used and liked the spline drive as well it's the shiznit
http://www.jonesracingproducts.com/
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570247
01/28/14 11:16 PM
01/28/14 11:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What I have is a countersunk screw with a allen head
and it comes up flush
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570248
01/28/14 11:41 PM
01/28/14 11:41 PM
AndyF Offline
AndyF  Offline
I have a crank trigger so that acts as a spacer. I used a standard OEM crank bolt. I didn't have to machine much off the backside of the spline drive hub, just a small pocket.
I used to make these spline drive hubs for Mopar engines but nobody bought them so I quit making them.
Re: BB Mopar Crank Drive Mandrels [Re: Al_Alguire] #1570249
01/28/14 11:48 PM
01/28/14 11:48 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Super nice stuff, have used them a little.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: BB Mopar Crank Drive Mandrels [Re: AndyF] #1570250
01/29/14 01:08 AM
01/29/14 01:08 AM
Out West
Out West
I have the trigger wheel as part of my balancer so my issue is 1/4" worse.
Re: BB Mopar Crank Drive Mandrels [Re: 408strokerdart] #1570251
01/29/14 10:52 AM
01/29/14 10:52 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
We have these made locally, used on circle track cars a lot. Nice quality. As with most of them BBC stuff, you may have to recess a tad in the back. I am considering making a few with BBM standard bolt pattern as well.
As far as off the shelf stuff, Jones hands down, nice quality,,and you pay for it. I used their stuff on small block Mopar circle track .
CV is nice quality, probably the biggest line up of pieces, but not as Mopar friendly with their offering.
Not a huge fan of the GZ " system". Although they have a Mopar version, I dont like how they put it all together so to speak, but he quality seems fine.
RIP Monte Smith
Re: BB Mopar Crank Drive Mandrels [Re: CompWedgeEngines] #1570252
01/29/14 02:05 PM
01/29/14 02:05 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Enderly Fuel Injection makes them.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: BB Mopar Crank Drive Mandrels [Re: Slingshot383] #1570253
01/29/14 02:36 PM
01/29/14 02:36 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
BB ???????
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: BB Mopar Crank Drive Mandrels [Re: Plumb Wired] #1570254
01/29/14 03:16 PM
01/29/14 03:16 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Weaver Brothers here in Carson City, Nevada.
Web site has alot to go through and doesn't have many pictures of their products but it is top of the line stuff
http://weaverbrothers.com/index.html
