Spline counts
#1570122
01/28/14 02:52 PM
01/28/14 02:52 PM
Posts: 304 Portland, Oregon
Digger73
Portland, Oregon
I have a question in respect to spline counts on axels and transmission input shafts. It seems that on axels, the more splines the better. On a transmission input shaft(manual transmission)the fewer the better. Now I'm not the brightest crayon in the box but what gives? I know that more splines means more surface area and in respect to axels larger dia. So why does it seem that there are two standards? Just something that I have been wondering about. Opinions.
Digger73(Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Spline counts
[Re: Digger73]
#1570123
01/28/14 03:29 PM
01/28/14 03:29 PM
Posts: 26,044 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I like more splines on the trans input because it makes it easier to stab in the hole (self aligns). 10-spline inputs usually require turning the output shaft to align the shaft/clutch disc.
Re: Spline counts
[Re: John_Kunkel]
#1570124
01/28/14 05:46 PM
01/28/14 05:46 PM
dogdays
It's a machine design thing. There are standard ratios of splines per pitch diameter. As most of the axle manufacturers use the same standard ratio (I forgot the name), on most axles the diameter of the axle is directly proportional to the spline count. So a 30 spline axle is smaller than a 35 spline axle. And because torsional strength goes up as the cube IIRC of the diameter, the 35 spline axle is much stronger.
On transmission input shafts it is again the diameter of the input shaft that matters. Here, different manufacturers use different spline counts for who knows what reason. So there are 10spline inputs in 1, 1 1/16, 1 1/8, 1 1/4, 1 3/8, etc. Then there are the fine spline, skys the limit.
On Mopar cars the 23 spline input is smaller in diameter than the 18 spline "Hemi" input. Guess what's stronger?
R.
Re: Spline counts
[Re: Digger73]
#1570125
01/29/14 12:05 AM
01/29/14 12:05 AM
Posts: 43,367 Bend,OR USA
Cab_Burge
