Page 4 of 9 1 2 3 4 5 6 7 8 9
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569866
03/11/14 01:27 AM
03/11/14 01:27 AM
Dreaming of the 808
AZ_A12_BEE Offline OP
Dreaming of the 808
Look ma, no heads
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569867
03/11/14 01:28 AM
03/11/14 01:28 AM
Dreaming of the 808
Dreaming of the 808
Pretty clean underneath
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569868
03/11/14 01:29 AM
03/11/14 01:29 AM
Dreaming of the 808
Dreaming of the 808
cast date 10-3-68
Re: 1969 Coronet R/T Resurrection. [Re: larry4406] #1569869
03/12/14 12:09 AM
03/12/14 12:09 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Check the pan on the engine. They used to use nylon coated timing gears for a "quite chain". My 71 barracuda with a 383-2bbl had timing that was all over the map.
Pulled the pan and found it full of nylon chips. Pulled the timing chain cover and the nylon gear blank had razor sharp teeth as the nylon coating was gone. Substantial timing back lash.
Cleaned the motor best I could, put in a TRW double roller timing chain and sprocket set (all metal) and kept on going.
That was an awesome car.
Back on topic, you are moving right along.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 1969 Coronet R/T Resurrection. [Re: OhioMopar] #1569870
03/12/14 12:21 AM
03/12/14 12:21 AM
Dreaming of the 808
Dreaming of the 808
With the possibility of hidden damage I have decided to do a complete rebuild at this time, including a new hotter cam.
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569871
03/15/14 12:54 AM
03/15/14 12:54 AM
Dreaming of the 808
Dreaming of the 808
Dropped the 440 off a the machine shop today, will know what needs to be done with it next week. I think the body is going to the body guy next weekend.
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569872
03/19/14 07:01 AM
03/19/14 07:01 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Moving right along.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 1969 Coronet R/T Resurrection. [Re: OhioMopar] #1569873
03/21/14 09:53 PM
03/21/14 09:53 PM
Dreaming of the 808
Dreaming of the 808
No word from the machine shop on the condition of the 440. Body man wants the car early next week so I need to strip off some of the trim off this weekend.
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569874
03/23/14 08:46 PM
03/23/14 08:46 PM
Dreaming of the 808
Dreaming of the 808
T5 double stack
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569875
03/25/14 12:37 AM
03/25/14 12:37 AM
Dreaming of the 808
Dreaming of the 808
Rear window is out, that 45 year old butyl sealer was a biotch to cut out
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569876
03/25/14 12:41 AM
03/25/14 12:41 AM
Dreaming of the 808
Dreaming of the 808
Typical rear window rust that we see here on the bottom and corners. We have tons of dust that lays in that channel and becomes a wet paste when it gets wet and just lays there. The car was outdoors and uncovered until I got it 1995.
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569877
03/25/14 12:41 AM
03/25/14 12:41 AM
Dreaming of the 808
Dreaming of the 808
Other side
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569878
03/25/14 12:42 AM
03/25/14 12:42 AM
Dreaming of the 808
Dreaming of the 808
Top corners are perfect
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569879
03/25/14 12:43 AM
03/25/14 12:43 AM
Dreaming of the 808
Dreaming of the 808
Other side top
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569880
03/25/14 02:12 AM
03/25/14 02:12 AM
Oh
His and Her 69's Offline
Oh
Looks like you need some metal work and a Dutchman panel replaced.
Heck my Ohio car didn't even need that much work in that area. Lol
(Mine was indoors for most of it's storage years though)
Keep plugging away at it.
David
Re: 1969 Coronet R/T Resurrection. [Re: His and Her 69's] #1569881
03/25/14 02:17 AM
03/25/14 02:17 AM
Dreaming of the 808
Dreaming of the 808
David
I got all the parts, this is as bad as I have seen here, that muddy paste will just sit there and stay wet for long periods of time. Of course I will eventually need to do the truck floor center nut not at this time
Re: 1969 Coronet R/T Resurrection. [Re: AZ_A12_BEE] #1569882
03/25/14 10:36 AM
03/25/14 10:36 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Man, that is rough! You should probably just send it on... I'll give you 200% of what you paid for it.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 1969 Coronet R/T Resurrection. [Re: OhioMopar] #1569883
03/25/14 11:40 AM
03/25/14 11:40 AM
Az
69hemibeep Online content
69hemibeep  Online Content
Az
Some good progress Dave
1969 Hemi Roadrunner 2nd owner
Re: 1969 Coronet R/T Resurrection. [Re: 69hemibeep] #1569884
03/25/14 11:41 PM
03/25/14 11:41 PM
West Central Wi.
1969 HEMI R-T Offline
West Central Wi.
Agreed! I will go 300%. but you have to deliver it.
HEMI,S ARE FOREVER!!!
Re: 1969 Coronet R/T Resurrection. [Re: 1969 HEMI R-T] #1569885
03/26/14 02:26 AM
03/26/14 02:26 AM
Dreaming of the 808
Dreaming of the 808
Scoop less
