Re: Street/strip guys: Front ends...poly or rubber??
[Re: 72demon416]
#1569711
01/30/14 02:40 PM
01/30/14 02:40 PM
Posts: 5,187 CT
GTX MATT
CT
What is the final word on this? None of the answers seem to be in agreeance, which style will allow for the best weight transfer between poly and rubber?
[Re: GTX MATT]
#1569712
01/30/14 03:51 PM
01/30/14 03:51 PM
Posts: 13,543 Marion, South Carolina [><]
an8sec70cuda
I have poly up front on mine. I just made sure my UCA bushings move freely to get weight transfer. They tend to be tight. Been 1.320 sixty foot w/ Cal-Tracs on radials.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: 72demon416]
#1569713
01/30/14 08:15 PM
01/30/14 08:15 PM
Posts: 23,554 Here
jcc
No soup for you!!!
No soup for you!!!
Here
So nobody has any experience with Nylon/teflon LCA bushings VS poly?
I'm using Delrin (nylon), poly is, IMo only a short term improvement over rubber, before it craps out, it really has, again IMo, a short useful life, and that that bothers me, as it has little warning before failure. I'm making my own Delrin to replace poly where I can.
I'm with Helmuth Hübener, and no soup is being served today.
[Re: jcc]
#1569714
01/30/14 09:53 PM
01/30/14 09:53 PM
Posts: 3,250 Between a rock & a hard place
cudadoug
So I am assuming you're making ALL of your nylon stuff, right? I don't find where nylon is available for Mopars and no user feedback anywhere, either.
[Re: GTX MATT]
#1569716
01/30/14 10:04 PM
01/30/14 10:04 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
There is no ONE answer for every car. The more power the car has, the less it has to rely on pitch rotation to make the car work, so a loosey goosey front with lots of travel is not needed.
One of the BIGGEST problems guys have now making their cars work, is that the fronts are TOO loose. They still think all that stuff that needed to be done in the 60s to make cars work on junk tracks, with junk tires, still applys today.......Not the case
Monte
[Re: Monte_Smith]
#1569717
01/30/14 11:28 PM
01/30/14 11:28 PM
Posts: 5,187 CT
GTX MATT
CT
Monte
Fair enough, whats the best guess on a mid 11 second 3800 lb 4 speed B body? Super Stock springs with 318 T bars
[Re: Monte_Smith]
#1569718
01/31/14 12:01 AM
01/31/14 12:01 AM
Posts: 11,704 W. Kentucky
justinp61
W. Kentucky
Monte
I'll take too loose and slow it down with shocks as opposed to too tight.
