Re: Street/strip guys: Front ends...poly or rubber?? [Re: 68LAR] #1569705
01/28/14 04:31 PM
01/28/14 04:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
All rubber on my street/strip Dart, it's been 1.38 60'. Would like to have tubular uppers and adjustable strut rods though.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: cudadoug] #1569706
01/28/14 11:28 PM
01/28/14 11:28 PM
Az
Crizila Offline
Crizila  Offline
Az
No question - POLY.
Fastest 300
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Crizila] #1569707
01/28/14 11:43 PM
01/28/14 11:43 PM
Mo.
racerx Offline
racerx  Offline
Mo.
All stock front with rubber best 60'1.28
Re: Street/strip guys: Front ends...poly or rubber?? [Re: cudadoug] #1569708
01/29/14 04:44 PM
01/29/14 04:44 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Since your 75% street I would stay with rubber. I switched my 69 Bee to poly five years ago and don't like it on the street. I'm going back to rubber. I never had alignment issues with rubber. I had to have it aligned twice so far with the poly in it and it needs aligning again. 100% strip poly.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Dabee] #1569709
01/29/14 06:41 PM
01/29/14 06:41 PM
Az
Crizila Offline
Crizila  Offline
Az
Rubber does cover up many alignment ill's.
Fastest 300
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Crizila] #1569710
01/30/14 12:32 AM
01/30/14 12:32 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
So nobody has any experience with Nylon/teflon LCA bushings VS poly?
Re: Street/strip guys: Front ends...poly or rubber?? [Re: 72demon416] #1569711
01/30/14 03:40 PM
01/30/14 03:40 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
What is the final word on this? None of the answers seem to be in agreeance, which style will allow for the best weight transfer between poly and rubber?
Re: Street/strip guys: Front ends...poly or rubber?? [Re: GTX MATT] #1569712
01/30/14 04:51 PM
01/30/14 04:51 PM
an8sec70cuda Offline
I have poly up front on mine. I just made sure my UCA bushings move freely to get weight transfer. They tend to be tight.
Been 1.320 sixty foot w/ Cal-Tracs on radials.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Street/strip guys: Front ends...poly or rubber?? [Re: 72demon416] #1569713
01/30/14 09:15 PM
01/30/14 09:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I'm using Delrin (nylon), poly is, IMo only a short term improvement over rubber, before it craps out, it really has, again IMo, a short useful life, and that that bothers me, as it has little warning before failure. I'm making my own Delrin to replace poly where I can.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: jcc] #1569714
01/30/14 10:53 PM
01/30/14 10:53 PM
Between a rock & a hard place
cudadoug Offline OP
cudadoug  Offline OP
So I am assuming you're making ALL of your nylon stuff, right? I don't find where nylon is available for Mopars and no user feedback anywhere, either.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: GTX MATT] #1569715
01/30/14 10:56 PM
01/30/14 10:56 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Heim joints are the best. But it looks like either will work and the poly lasts longer and is stiffer for better handling. I have had energy suspension bushings in my car for ten years with no problems, so I would go that route.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Street/strip guys: Front ends...poly or rubber?? [Re: GTX MATT] #1569716
01/30/14 11:04 PM
01/30/14 11:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
There is no ONE answer for every car. The more power the car has, the less it has to rely on pitch rotation to make the car work, so a loosey goosey front with lots of travel is not needed.
One of the BIGGEST problems guys have now making their cars work, is that the fronts are TOO loose. They still think all that stuff that needed to be done in the 60s to make cars work on junk tracks, with junk tires, still applys today.......Not the case
Monte
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Monte_Smith] #1569717
01/31/14 12:28 AM
01/31/14 12:28 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Monte
Fair enough, whats the best guess on a mid 11 second 3800 lb 4 speed B body? Super Stock springs with 318 T bars
Re: Street/strip guys: Front ends...poly or rubber?? [Re: Monte_Smith] #1569718
01/31/14 01:01 AM
01/31/14 01:01 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Monte
I'll take too loose and slow it down with shocks as opposed to too tight.
Re: Street/strip guys: Front ends...poly or rubber?? [Re: justinp61] #1569719
01/31/14 08:44 AM
01/31/14 08:44 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
I used poly and I did what and old racer told me to do . Grease it very good and use nylon loc nuts on cam bolts. After you get it aligned just do a couple of spot welds on the cam just to lock em on place but in a easy spot if you need to grind em out . Now loosen up cam bolt just enough to let the arm move free Works like a charm.
