One of the easiest choices these days is the Rev'Nator (orange box compatible), with an integrated RPM limiter. No real reason to use an MSD-6A for a street car with that on the market.
Using an OEM ECU bracket (1972 and after) makes this look *factory*, if not year-correct.
You can even get new engine harnesses modified for electronic ignition if you don't want to hack you own.
If you want to stay close to the OEM look (no electronic ECU on the firewall), the options are :
- A Pertronix module in a points distributor (I'd say keep a spare module in the glovebox, in case you leave the ignition on and fry it),
- A Points distributor triggering a MSD-6A or equivalent box, hidden away somewhere (quite a bit of wiring to hide if you're going for the OEM look).
- An HEI conversion, with the HEI module on a
heat sink bolted under the electronic distributor you already have.
