Mocked up my dual line oil system today, look ok? #1569174
01/26/14 09:16 PM
01/26/14 09:16 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I was going to just cap off one of the pick ups because of clearance issues up front with alternator belt but I picked up one of Milidon's oil pumps and a low profile 90 degree fitting and everything cleared so I mocked up the oil system today to see if I needed to make new lines or get new fittings but I think it may work with what I have.
I'm using a 400 block and a set of 906s just to check header clearance. The higher deck height on the RB block and raised exhaust ports on the 440-1s will just give it more clearance.
I'm using the Milodon 31161 9qt pan
Milodon dual line pick up and hoses (used)
Milodon 21815 aluminum dual line oil pump
Muscle Motor's pump cover, discovered that the oil pressure relief hole wasn't threaded deep enough. Neither the stock or the Milodon fitting will seat to the flange, easy fix just one more thing to fix but still like it)
Muscle Motor's oil pan gasket (reusable rubber coated steel lined and has steel bosses at the pan bolt holes to keep you from over tightening)
The lines don't touch the block, the pump, the motor plate or each other and there is room to run the dip stick tube between them.
Anyone have any concerns with this set up? Do I have the lines routed right so the pump won't loose prime?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: Mocked up my dual line oil system today, look ok? [Re: WadeMetzinger] #1569175
01/26/14 09:17 PM
01/26/14 09:17 PM
Tulsa, Ok
Tulsa, Ok
2nd pic
Re: Mocked up my dual line oil system today, look ok? [Re: WadeMetzinger] #1569176
01/26/14 09:19 PM
01/26/14 09:19 PM
Tulsa, Ok
Tulsa, Ok
3rd
Re: Mocked up my dual line oil system today, look ok? [Re: WadeMetzinger] #1569177
01/26/14 10:19 PM
01/26/14 10:19 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
That how ya do it!
Re: Mocked up my dual line oil system today, look ok? [Re: camastomcat] #1569178
01/26/14 11:27 PM
01/26/14 11:27 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Yup, that's it!
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Mocked up my dual line oil system today, look ok? [Re: bigtimeauto] #1569179
01/26/14 11:55 PM
01/26/14 11:55 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
don't forget to check the starter, back line looks close
Re: Mocked up my dual line oil system today, look ok? [Re: cudaman1969] #1569180
01/27/14 12:09 AM
01/27/14 12:09 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
^^^^^^^^ yes the starter might be close on that. Here is how mine are:
Re: Mocked up my dual line oil system today, look ok? [Re: bigtimeauto] #1569181
01/27/14 12:34 AM
01/27/14 12:34 AM
illinois
rbkt65 Offline
rbkt65  Offline
illinois
wade this is rick Woolsey buddy of guy from gateway with 64 polara wedge sled. is there going to be any possible concern with cavitation on this set up as garys 64 has been doing crazy things to bearings. we changed pans twice but machinist thinks cavitation may be problem. we have line run up over like yours. just asking. thanks rick
Re: Mocked up my dual line oil system today, look ok? [Re: rbkt65] #1569182
01/27/14 01:43 AM
01/27/14 01:43 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You may want to use a pair of these,saved my butt more than once
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Mocked up my dual line oil system today, look ok? [Re: rbkt65] #1569183
01/27/14 01:44 AM
01/27/14 01:44 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Cavitation is due more to the rotor design than line routing. The milodon "star" rotor has a tendency to Cavitate, the stock rotors do not.
Re: Mocked up my dual line oil system today, look ok? [Re: Stanton] #1569184
01/27/14 03:01 AM
01/27/14 03:01 AM
Tulsa, Ok
Tulsa, Ok
Hemi-ITIS are those 1 way check valves? (To prevent the oil from draining back?)
What is meant by cavitation? Are you meaning that the Milodon pump's suction causes the supply lines to collapse? Or does the pump lose prime and sort of vapor locks even though they is oil in the lines it can't pull it? If your meaning that the lines collapse I may replace them with tephlon lined hoses just to be safe.
I also run a Master Lube accumulator system that I use to pressurize the oil system prior to starting and it also keeps the system pressurized if and when the oil pump looses prime in my old system but was thinking I wouldn't have that issue with the way I'm routing the lines with this oil system.
Re: Mocked up my dual line oil system today, look ok? [Re: WadeMetzinger] #1569185
01/27/14 12:14 PM
01/27/14 12:14 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Those are pre-filters in his photo.
Cavitation is the formation of vapour cavities in a liquid – i.e. small liquid-free zones ("bubbles" or "voids") – that are the consequence of forces acting upon the liquid. It usually occurs when a liquid is subjected to rapid changes of pressure that cause the formation of cavities where the pressure is relatively low. When subjected to higher pressure, the voids implode and can generate an intense shockwave.
I don't think the lines will ever collapse. In order to collapse there would have to be a restriction on the inlet such that the outlet flow would be greater. Since the feed line in the block is only around 1/2" and you have dual inlet hoses, I can't see where there'd be a restriction. And even then, I don't think an oil pump could generate enough suction to collapse -12 braided hose.
Even the cavitation would likely only happen at the top end of the rpm scale - if it happens at all.
Just my thoughts.
Re: Mocked up my dual line oil system today, look ok? [Re: WadeMetzinger] #1569186
01/27/14 01:05 PM
01/27/14 01:05 PM
hemi-itis Offline
hemi-itis  Offline
They are pre filters with screens in them.If something comes apart and gets in the oil pan,these will stop any large objects to get sucked into the oil pump and sent through the engine.They unscrew so you can check the screen for debris. These were originally recommended to me by Jimi Vignogna.
Re: Mocked up my dual line oil system today, look ok? [Re: hemi-itis] #1569187
01/27/14 01:32 PM
01/27/14 01:32 PM
ok
mopdragster Offline
mopdragster  Offline
ok
I'd prefer to run the back line under the front line like in Bigtimeauto's pic. Maybe gravity will help keep at least one line full of oil when sitting and for startup may help get pump primed and pressure sooner.
Re: Mocked up my dual line oil system today, look ok? [Re: mopdragster] #1569188
01/27/14 02:35 PM
01/27/14 02:35 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I prefer to have the lines take the "low way" from the pump to the pickups. Helps make sure that oil stays in line so you do not loose prime, at least thats how I feel.
Re: Mocked up my dual line oil system today, look ok? [Re: Al_Alguire] #1569189
01/27/14 03:05 PM
01/27/14 03:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I set up my lines pretty much as Wade has his..with
a little hump up to go above the pump... that way only
the oil from the bottom of the hump to the pan can
drain back and it always has oil in the pump and will
always prime
EDIT
I use the pre filters also, just to try and save the
pump if something lets go... the prefilters are a
MUST on a dry sump pump... they cost way too much
to let trash into the pump
Re: Mocked up my dual line oil system today, look ok? [Re: rbkt65] #1569190
01/28/14 02:12 AM
01/28/14 02:12 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
My thinking you are sucking air at a fitting(cracked) or at the swinging pickup. Could be a crack in an oil passage running to the mains.
Re: Mocked up my dual line oil system today, look ok? [Re: cudaman1969] #1569191
01/28/14 01:40 PM
01/28/14 01:40 PM
Tulsa, Ok
Tulsa, Ok
I checked starter clearance last night and there is enough room, not a lot but it will work.
Thanks for all the feedback and input guys!
